Status
Not open for further replies.
1 - 19 of 19 Posts
1994 Bronco 351W, E4OD 6" Superlift, 35 BFG KM3 4.56 gears Detroit
Alright guys this one is back up for sale and i need it gone soon!!!. The AOD trans is in need of some work, it needs a new Valve Body the TV valve and 1-2 shift valve are shot.
$2500
1989 Ford bronco
5.0 crate motor from ford with less than 10,000 miles on it
AOD trans with rebuild about 20,000 miles ago
BW1356 T-case just rebuilt with about 100 miles on it
Leaf spring Dana 60 kingpin front axle with 4.56 gears and welded spiders. 35 spline inners and 30 spline outers Warn standard Hubs Ford 1ton calipers. Off road unlimited crossover steering arm
Dana 70 rear also with 4.56 gears and a 35 spline power-lok. Disk breaks using chevy 3/4 ton calipers.
13-36-16 TSL swampers on 16x10 on black rockcrawler steelies. 2 tires have 1/8 tread left the other 2 just over half tread.
12 inch travel Rancho rs8000 shocks
custom built rock sliders and rear bumper, newer ford super duty seats.
Dual Batteries and dual electric fans. 180 amp alternator. Ford motorsport underdrive pulleys. Mac shorty headers
saginaw power steering pump upgrade. Custom built Trans crossmember and long travel square drive shaft. Brand new heavy duty aluminum radiator. A/C Blows cold but needs a charge, it has a slow leak but all components were recently replaced including the compressor. it does need some minor exhaust work connecting to the headers as the pipe flanges are a bit too small for the ball flange on the headers
Carpet was removed and inside painted with herculiner roll on bedliner. Also has an aftermarket roll bar.
The body has some minor rust in a couple of spots but is pretty solid (except the tailgate which is ate up with rust.typical Bronco problem) also has some dings her and there. it aint pretty but she makes a good trail rig.
crappy stereo and cb are included Hi-lift not included.
$2500 Open to some partial trades maybe a nice rifle or handgun and some cash or another Bronco and some cash!?!?!?!?!. The axles and Engine alone are worth that much!!!! Truck is located in Arlington area of Jacksonville.
Jason 386-937-4548
fishin' without dad
I pulled the pan to replace the gasket(fix small leak) and change the filter(while in there). Found a small dent in the filter( coinciding with the small dent/crease in the pan. Beat the pan out with a hammer and 2x4 and put new filter in and tapped the bolt hole that was stripped(cause of leak). Installed pan, poured fluid and drove it around the block. It shifted through 3rd. I stayed in the neighborhood(neighbors started towards my house at 10:30 at night)LOL. I started out to also pull the valve body and run it through the parts washer but when I found the filter I thought that had to be the problem and gave it a shot.
Trade for a 2003 KFX400?
-Curtis-
I am assuming thats a motorcycle, sorry cant do it.
It's a 4wheeler. Motorcycle/4wheeler same thing. lol If i had the money id sweep it up. Bug ethan about buying it!
-Curtis-
formerly Nascarfreak88
-Curtis-
I have the money to buy it, but what am i going to do with the dodge? I will loose my ass off that thing if i parted it out... and who will buy a half ass done project? All the dodge needs is steering box, steering links, trac-bar, brakes ran, brakes re-done on all 4 corners, and drive shafts shortened along with yokes on each axle. Then again, for the price of all that, i could almost buy this Bronco.
If this would have been for sale at the beginning of the summer, i would have 100% bought it.
Discussion Starter · #13 ·
If you buy it i will also throw in all of the Hydro assist stuff, Just needs to be installed.
Discussion Starter · #15 ·
is the motor stock specs or running some more power?
No its stock internally with shorty headers underdrive pulleys and no mechanical fans. It is a Ford Motorcraft crate motor. it only has about 10,000 miles on it
Discussion Starter · #16 ·
All this Bronco needs is some exhaust work because the flanges are too small for the header flanges. It is rigged up temporarily but it does leak some. Hell if you buy it i will even put the built back bumper on shown in the pics.
Come on you know you want it!!!!!!!:thumbup
1 - 19 of 19 Posts
Status
