1 - 20 of 23 Posts
These are the parts I have removed and priced so far (all parts are in good condition or in working order):
Grill - $30 (missing emblem, good clips)
Smog Pump - $20 (spins freely)
lower valance grill insert - $30 (nice and straight)
Rear Bumper - $50
Tire Carrier - $20
doors - ($30 each) door panels ($20 each) mirrors ($10 each)
Hood - $40 (small paint bubble and small crease)
Cap - $200
* - Tailgate, Engine and Tcase are not for sale. Ill be adding additional parts and prices as I remove them.
What transmission does it have? I am mildly interested in a spare E4OD on/off switch.
thanks
tim
Actually I'm not sure of which trans is in there. Ill have to check.
Bump
Roller rockers are gay
Probably an AOD since it's a 302.
Good luck with sale(s).
Yea it doesn't have the OD button at the end of the shifter. Doesn't that mean AOD?
Yes and no. That particular year had a different panel beside the steering wheel with an on/off switch. If you have a cubby/storage hole in this panel above your right knee while driving it isn't an E4OD. The switch I am talking about replaces the "cubby hole".
tim
Oh I see. Ill take a pic of that area when I get home tonight. Pretty sure there is a cubby hole.
I wouldn't see why not bud. Ill take a picture of that also.
Discussion Starter #12
Yes. Ill get pics if you'd like.
Yea that would be great. I replaced the fabric on mine, but most of the crumbly stuff that gives it support is gone. I was going to use yours to put under it to give its form and contours back.
Discussion Starter #14
Looks at it last night. Its all torn and hanging. Don't think you'll want it.
X - I need some patch panels. How bad are the following:
1) Rear corners of the bed. I really need that rear body support piece, but if the ends are rotted off (as they usually are on Jersey) I'm probably going to rebuild my old one... some how...
2) The inner wheel wells - from inside the rear seat/cargo area of the truck. Mine are pretty bad, and I tried cutting some from a F-150 bed, but they are slightly different. I'm not referring to the pieces that are welded into the upper part of the wheel well from the outside, but the actual wheel well itself.
3) The outer b-pillar sail panels. I need the passenger side, but I'll take both - you never know.
I'm guessing that you won't be dealing with the body until it is completely stripped, which is fine, but I figured it I'd ask now. Thanks!
Discussion Starter #16
Some guy is coming to pick up the front seats tonight. Once those are gone I can remove the rest of the carpet and get some pictures for you.
Can you get a pic of the headliner? I am ok if the fabric is torn off; I just need the shape of it. As long as the squishy stuff that makes it ridged is there.
I'm interested in the outside driver-door mirror, inside windshield mirror, horn, parking brake pedal and cables, speedo cable, and some other things; I'll need to get a list together for anything else. Shipping would be to 76530.
Also, how's the fuel tank?
Discussion Starter #19
Mike, sorry its pickup only for now. I just wouldnt have the time right now to put all of that together. Although I may be getting laid off in a few weeks and in that case things will change.
No problem..my bad for not seeing the "pickup only".
More importantly, hope you don't get laid off! (I got laid off a couple months ago, and still looking for something; sucks being out of work...but there's more time for projects!)
1 - 20 of 23 Posts
