1 - 3 of 3 Posts
1989 Ford Bronco Full Size
The power door locks do not work after removing the door panel it appears someone at some point cut the wires and removed the actuator. With this being said I know you can find the actuator online but does anyone know where you can find the wiring harness that plugs into the actuator?
Yo DM,
Harness:
For a YARD SEARCH on-line, I use;
Hollander Quality Replacement Parts | Find Used Auto Parts | Online Locator
A yard that uses Hollander Interchange can search other yards and have it shipped including some Canadian yards.
"...For over eighty years, Hollander has been making the best tool for fast, interchangeable part matches. The new Edition Hollander Interchange contains more interchangeable options than ever before.
The Hollander Interchange provides auto recyclers and auto collectors, rebuilders, and others with the easiest and most comprehensive solution for identifying interchangeable auto parts..." See their yard Directory @ Seller Directory | Used Auto Parts | Hollanderparts
Can select a certain part.
Harness isn't listed, so Search for: 1989 >Ford > Bronco > Doors > Front Door Switch > Alternate Front Door Switch
Many results! Such as;
171635
or
Car-Part.com--Used Auto Parts Market
Can select certain parts
Can search by year range,
Door Lock Actuator, 1989 Ford Bronco:
Dorman Door Lock Actuator Motor - Front Left or Right
Dorman logo
$40.43 or shop for lower price
(5 Reviews) 5 Stars
Our List Price:$40.43. Quantity: (46) In Stock
Part Number: 4964-05220744
Notes: Door Lock Actuator Motor
Features:
  • Has undergone extensive quality and safety performance testing
  • Engineered to provide the same fit and function of the original actuator
  • Part has undergone simulated crash testing under government guidelines
  • Long-lasting repair - cycle testing in an actual vehicle door verifies effective usage for years
Condition: New
Package Contents 1 Door Lock Actuator; Six Activation Rods
Shipping Options:
@ 89 1989 Ford Bronco Door Lock Actuator - Body Mechanical & Trim - ACI, Brock, Dorman, Standard Motor Products, Front, Front Left, Front Right - PartsGeek
Or most parts stores, such as @ O'Reilly Auto Parts
@ https://www.oreillyauto.com/shop/b/...-actuator-11136/1c17b0d5b62c/1989/ford/bronco
1 - 3 of 3 Posts
