Two years ago, I bought a 1988 Ford Bronco XLT with a 351W EFI, C6, dual shock setup with 3.06 gears. It had lived it's life as a plow truck for a local A&W in Northern Wisconsin. It had 68000 Original miles on it in 2009, which is only 3200 miles per year. It came with a Meyer Plow in working condition. When I bought it, I didn't care about the body, only the mechanicals. It didn't run when I got it, which was remedied with a new TFI and distributor. Anyway, after plowing my driveways for the last two years, I am getting sick of the exhaust flowing in through the floors. The passenger seat belt pulled out of the floor, I think the only thing holding it in was the carpet. Here are a few pics
Rusty Doors and Body[url=https://www.supermotors.net/registry/media/891041]
[/URL]
Rockers and doors are Gone...[url=https://www.supermotors.net/registry/media/891042]
[/URL]
[url=https://www.supermotors.net/registry/media/891043]
[/URL]
[url=https://www.supermotors.net/registry/media/891044]
[/URL]
The interior is very nice though...
Check that headliner, not bad for 23 years...[url=https://www.supermotors.net/registry/media/891046]
[/URL]
Not much of the rear quarter left...[url=https://www.supermotors.net/registry/media/891047]
[/URL]
The passenger side is no better...
The gears are a little high for plowing, but the 351 is strong, the plow works well, as does the heater...not a bad truck for $725 out the door...
BUT...
I just couldn't handle the body any longer. It seemed that this winter, my seat just might fall out on the road I was plowing with me in it...
The floors are that bad, rotted along the rocker seam from pedals to rear seat, both sides...can touch the carpet all the way...
I started watching craigslist and found a 1989 with a bad, partially disassembled motor, but what appeared to be a good body...only catch, it was 860 miles away in Georgia and I had to base the condition of the body on photos texted to me from a phone...a bit of a gamble.
I initially had to convince my wife that this WAS a necessity, not just a new toy for me. I then located and borrowed a car-dolly (incidentally, did you know that Ford Bronco's are really just too wide to fit on a car-dolly and will require some creativity to keep them attached at highway speeds?).
Next order of business, a co-pilot...hmmmm, I guess I will convince my father to drive with me and take along my 10 year old son for the adventure. It was three generations in the same truck and made for a great experience....
My dad, not being one to waste time on such trivial things such as sleep, convinced me that we would drive all night, straight through, load up the bronco, and drive straight back without a single stop to sleep. He says, and I quote, "you can can catch an hour while I drive and I will catch some when you drive"
We made arrangements with the seller and left on a Friday night at about 5:30 pm from Madison, WI. We drove straight through the night arriving in GA at about 7am, 13 hours driving, about an hour total for all the gas stops,etc. We had breakfast at a "Waffle House" (what's the deal with Grits anyway?) and began hooking up the new Bronco by 9am.
Immediately left for home and arrived back in Madison at 1am Sunday morning, roughly 31 hours round trip with stops and hookup/retrieval time.
I gotta say a Bronco that has lived it's life in Georgia is a far cry from one that has lived in Wisconsin. This 89 Bronco has less rust on it's frame and floor pans than my 2006 F150 Super Crew has, I am totally serious, take a look...
Here it is...
Check out those rockers...
And those fenders...
Previous owner had coated the floors in a bedliner, which is now peeling because he didn't scuff the original paint. I am amazed at how clean and rust free the floors are, even the original gunk under the carpet under your feet is still there and in great shape...
And here are the floor boards...the brown/redish color you see is red mud from Georgia, there is literally no rust, the paint doesn't even looked scratched...
This is looking toward the front from driver's side rear tire...
Passenger side...
Here is in insides of the rear fenders...wow..
Drivers Side...
Pass Side...
And finally, the real test, the tailgate...look at that bottom seem...unbelievable...not even swollen with rust yet...
I pulled the carpet up because it was in rough shape, check out the floors...nice and solid and the rear bedliner appears to be holding...
I can not find any rust on the body. It does have a few dents in the passenger side, one can be seen on the bottom of the passenger rear quarter, and there is a big dent in the passenger door and door jamb of the passenger side. For the record, I would prefer 10 dents for every piece of rust that needs to be cut out and replaced on a restoration...
All in all, I don't thin it was a bad find for $700...
It also has LSD rear, 3.55 rears, custom chrome rims
and 33 inch tires. The small pieces that are missing can be found on mine.
I have already located a pair of GT40 heads which I will rebuild and put on my 351, all the parts and ECC for MAF conversion (Mustang A9P Ecc, wiring harness from maf F150 5.0 (1994), Pacesetter headers, custom y-pipe, removal of one cat, cherrybomb. I will bump up the cam, building for low end grunt (read torque). I would like to get it to 300hp, 400 lbft with these mods. For the time being I will keep factory intake...
So some early questions are...
I am contemplating pulling the body off to coat the frame and coating the underside of the body and re-coating the inside of the tub...I want this to last. I am going to continue to use it as my plow truck, but would love to have it completed and nice so my son and daughter could use it as an occasional driver to school when they reach driving age (about 5 years away).
What is my best choice for adhesion and sealing properties on the interior. I have read about duraback, por15, eastwoods product and rust bullet. I really have no rust to encapsulate or bond to, so I am looking for best solution for prevention of rust on the inside.
Underside of tub is same story, no real rust to bond to, but I want to keep it that way...what is my best option out here, rust bullet probably?
and for the frame and axles, Por 15 all the way or is there a better alternative. Don't get me wrong, not important that this looks like a trailer queen, it does, however, need to last...
Lastly, I need to pick a color. The EB interior that came with the truck is less than desirable. Seats are ripped, headliner sagging, plastic trim broken and missing...therefore I plan on using my red interior from my 88 as it is near perfect. I need to find a color that will look good with that interior color. I already own a black Ford truck and a Black Honda Accord, so I would like to steer away from black again..anyone seen something that looked really good or have an idea for an exterior color?
I will keep the updates coming and continue to post pics...Thanks in advance for all the info on this site. It is always nice when people can come to this site and receive honest, helpful advice on their Bronco questions, whether they are historical specification questions or simply "whats wrong with my truck" questions...keep up the good work...
Bratcop
BUT...
Here it is...
Passenger side...
Drivers Side...
Pass Side...
Bratcop
