Okay, I read all of the posts on hubs, but noone seems to address how to get the 3-nut hub off. I've got the cap off, but then there is a secondary aluminum cover that doesn't come off easily. Do I need a special tool? Is there a pin holding it? I can take a picture if that would help.
(Not interested in coverting to manual hubs since I never go 4X4...) :brownbag
Yes pics please. I imagine you need to get out the retaining ring. If you are not replacing them what are you taking them apart for?
Ahhh, you're right. Won't bother posting a pic. Gotta take out that retaining ring...
I'm not replacing because I think the bearings went out. Weird thing happened today. I was driving and as I stepped on the brake the left front inner shoe was pushed out of its place and dropped to the road (luckily I was getting into my driveway and quickly used the parking brake to stop. There is about a 3/4" of play in my rotor. I'm thinking it is the bearings or the shop I had the rotors turned at a couple months ago didn't tighten it on good enough. Any thoughts on that?
Yup. Sounds like your whole wheel hub assembly is about to fall off. Good thing you found it when you did or it could have been a real mess. They probably didn't torque down the hub nut correctly. Give em' a call and tell them what happened.
Repo'd
Wow, that sounds firmiliar.
Same thing happened to me last month.
If it went that bad, you need========
A new hub,
new bearings/inner and outer
New spindle. You will see why when you get the hub apart
Spindle nut kit.
and possibly a new caliper
As for not replacing the hubs to manual.
You will save money purchasing a pair of manual warns.
A new auto hub is very expensive.
Have fun either way though
