1 - 8 of 8 Posts
1990 ford bronco, 4.9l, e4od,
I have a 1990 ford bronco with a 4.9l and e4od. when i put it in drive its like its in 3rd gear like a limp mode type thing. I've had it rebuilt with new converter replaced the solenoid shift pack, the VSS, the rmp reader, NSS, TPS, and the PCM. Have no idea whats causing it not to shift not getting any codes relating to the transmission. Any help would be appreciated.
Ultra Premium Member
I know you said you replace the VSS, but this may be a stupid question, but is your speedometer working?
Yo 1990 4.9l,
Welcome!
Edit
Shift Concerns: Some or All Shifts Missing
Possible Component​
Reference/Action​
210 — ELECTRICAL ROUTINE
Powertrain Control System
  • Perform Shift Point Road Test.
  • Electrical inputs/outputs, vehicle wiring harness,powertrain control module, throttle position sensor, Transmission Range (TR) sensor, vehicle speed sensor, shift solenoid 1, shift solenoid 2
  • Run On-Board Diagnostics. Refer to Powertrain Control/Emissions Diagnosis Manual for diagnosis. Perform Service Manual Pinpoint Tests A and D using the Rotunda Transmission Tester 007-00085, Cable and Overlay 007-00107 and the Transmission Range (TR) Sensor Cable "B" (MLPS Manual Lever Position Sensor Cable) 007-00086 or equivalents as outlined in this section. Service as required. Clear code, road test, rerun On-Board Diagnostics.
310 — HYDRAULIC/MECHANICAL ROUTINE
Fluid
  • Improper level
  • Condition
  • Adjust fluid to proper level. Inspect according to instructions under Fluid Condition Check.
Shift Linkage (Internal/External) or Cable
  • Damaged, misadjusted, disconnected
  • Inspect and service as required. Verify linkage adjustment as outlined. After servicing linkage, verify that the transmission range (TR) sensor is properly adjusted. Refer to In-Vehicle Service in this section.
Filter Assembly and Seal
  • Plugged, damaged
  • Inspect filter assembly and seal for damage. Service as required.
  • Filter seal damaged
Main Controls
  • Valves stuck, damaged, misassembled
  • Inspect for damage. Service as required.
1990 Bronco Pre-Delivery Shop & Electrical & Vacuum Troubleshooting Manuals (EVTM), Partial by member Kingfish999 in Google Drive @ 1990 Ford Truck service manuals - Google Drive
1990 Ford Truck Emmisions Manual.pdf by Ford via member 90.CaliBronco in Google Drive @ 1990 Ford Truck Emmisions Manual.pdf
Suggest you download both for faster scrolling and to use the table of contents index.
1990 Ford Bronco Brochure by Ford via Dezo's Garage @ https://www.xr793.com/wp-content/uploads/2020/07/1990-Ford-Bronco.pdf
Register with VIN to see most Ford dealer maintenance/repairs done @ any dealership nation-wide @ Welcome to Ford Owner | Official Ford Owner Site
For any Bronco issues or to chat about it's planned modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories that requires 75 non-padded posts to participate due to scammers who preyed on our members.
Our Forum FAQs includes for example: How To Upload Images To Posts, How to Use Search and more tips!
➡See Baba Looey's Favorite FSB Links (lots and lots of tech links) ... includes such as, "Tailgate Window repair & troublehooting".
Try to find time to participate and vote in our Full-Size of the Month Contest & CURRENT Full-Size of the Year Contest @ Voting
You will get ideas by those competing. Also see the prizes! They are awesome as compared to other sites' "contests"!
Al
fluid levels are good and just changed the fluid too. its leaking out the rear main seal though
It may be acting like it's stuck in 3rd gear because it is. Most electronic transmissions will default to a certain gear when there is no electrical input to the shift solenoids. It's often 3rd gear which is usually a direct 1 to 1 ratio. That would mean a lack of command from the EEC, could be bad wiring or connector though.
ive tested the wiring and replaced a few harrnesses. I replaced the EEC and tested signal to the tranny and its good. im really stumped on this one.
ate lug
88 + 96 broncos, 96 F250
The E4OD should default to 1st gear in the event of an electrical failure, but thats not always the case. Hook up a scanner and check live data, see what it says.
  • 1st gear : Solenoid 1 on, Solenoid 2 off
  • 2nd gear: both on
  • 3rd gear: Solenoid 1 off, Solenoid 2 On
  • 4th gear: both off
First verify that those are working, either by checking live data thru the PCM, or youll have to back probe the harness and check that way. You said you dont have any codes, which means it is probably not a solenoid issue but you should verify it. Considering youve checked everything else, if this doesnt turn up anything else then id have to assume a mechanical issue with the transmission.
1 - 8 of 8 Posts
