Where is/are the relay(s) for the turn signals on a 1993 Ford Bronco XLT 4x4? Can anyone dig up some diagrams?
yo,
What is the issue with the turn signals?
Some info for you to use to help describe thAngs;
Multi-Function Switch (MFS), Hazard, Turn, High & Low Headlight Dimmer, Flash-to-Pass & Brake Light Testing & Wiring Diagram in 92-96; "...the MFS testing is done with connectors disconnected; it's strictly an internal test of the MFS; ..." Miesk5 NOTE; Brake Light &
Turn, High & Low Headlight Dimmer, Flash-to-Pass & Hazard CKTs
are a Feed-Through Circuit in Multi-Function Switch (MFS) Source: by Steve83 (Steve, That dirty old truck) at
http://www.supermotors.net/registry/media/225114_1
see Steve's captions in the Page, such as;
IF THE IMAGE IS TOO SMALL, click it.
Use these photos for access to the MFS:
Use these to repair it:
And see my site @ for
http://www.broncolinks.com/index.php?index=125
Multi-Function Switch (MFS) Testing from 1996 F-150, F-250, F-350, Bronco, F-Super Duty Motorhome Chassis Workshop Manual
it is the std Ford drill from PINPOINT TEST J: ALL TURN SIGNAL LAMPS/HAZARD FLASHER LAMPS INOPERATIVE
J1 CHECK FUSES
Check turn/hazard
Compare wiring colors and ckt numbers w/
Turn, Tail, Brake & High Mount, Head Light, Side Marker, Hazard Wiring Diagram in 92-95 Bronco & F Series
