1 - 3 of 3 Posts
i just bought my second bronco last week and it seems to have a low speed speed hesitation or miss? only going slow with very light gas pedal depression. if i floor it or give it about half pedal off a stop sign it runs fine. The idle is a bit rough too, especially when its cold. i have checked all the plugs and wires, they look new but i didnt install them, i tested the tps and the voltages are in range at idle and wot. i cleaned the maf, and the iac. what else could be causing this problem? im at a loss. any ideas would be helpful. thanks
How are the wires routed do they follow diagram to prevent crossfire?
Check to see what color ICM you have, it should be black, if not. get a black one.
Pull codes, even if you don't have a Check Engine light, the computer will store codes. As you just got the Bronco. write down the codes, clear them, and then see if any recur in a week or so. You probably don't know how long ago the PO cleared the codes, so no use chasing something that might've happened years ago.
1 - 3 of 3 Posts
