1 - 4 of 4 Posts
1994 Ford Bronco XLT, 5.8L, Automatic , Manual Hubs, Stock
Hey all, super excited to have found this forum. I bought a 1994 Bronco XLT this week it’s a project but runs, and ac works. Paid $1k maybe a little higher than I wanted to but it used to belong to Dickie Betts lead guitarist for the Allman Brothers and has some nice upgrades like full custom sound system.
172106
It needed a new radiator so I ordered a full aluminum radiator and began with that install. The top transmission cooler line was real stubborn and ended up snapping, the bottom cooler line also was in bad shape. Should I replace the full lines or just rig up a fix?
172107
Has a few rust issues but the floorboards are solid.
172109
172112
172115
172116
172117
I can handle most work but not these rust areas. Need help getting started on this project. Outside of finishing the radiator swap, what’s the best place to start? Wheels look like they will clean up nicely.
172118
but any advice from those that have done this before would be greatly appreciated. I’m open to spending some and getting it fixed up right but main goal right now is to get the radiator/ transmission cooler lines fixed up so I can run it a bit.
It’s also having a bit of an electrical issue where the power to the radio goes on and off periodically. It was sitting for 5 months outside so weather has made its way inside the vehicle. 🤷‍♂️
172119
172121
Yo Ron,
Welcome! I think you made a very good deal!
We replaced such rust sections with panel patch panels for 1/4 and tail gate from MILL SUPPLY, Cleveland, OH
1987 Ford Bronco Repair Parts | Mill Supply, Inc..
They were primed and of 18 gauge steel - exact fit around wheel well arch and packaged very well for shipping.
Upper rear wheel arch area; see other panels.
In lieu of welding the panels in-place, consider "Silaprene Adhesive/Sealant, bonds body panels, body seams, roofs. Adhesive will not allow panel to come loose. Used to mount or fasten just about anything together. An adhesive sealant made to last. Actually gets stronger with age, won't brittle or crack from vibration or thermal shock. Withstands extreme temperatures, unaffected by highway chemicals. Used by body manufacturers. Six month shelf life. 10.1 fluid oz. caulk tube, gray in color." by Mill Supply
Replace transmission cooler lines, don't need rust roaming around in your E4OD transmission.
Inline Tube @ Inline Tube | Preformed Lines, Brake Products, DIY & Restoration Parts - Bronco/Ford truck pre-formed brake, power steering & transmission cooler line sets, hoses, fittings, & rubber fuel hoses, etc.; exhaust systems; parking brake cables; gas tanks, etc. Call them since not all parts are shown on-line.
Or stop by local NAPA and discuss it with a live wire person.
Have the new radiator internal cooler flushed (seen some new units left in filthy shops too long before they were installed) and change E4OD fluid if seller hasn't provided recent maintenance receipt.
Radio intermittent or inoperative; see troubleshooting @ 1996 Bronco/F-Series
Its from 1996 Bronco/F Series Workshop Manual (see link below) that is similar to 94.
Corroded connectors are simplest test.
172132
ASAP, find out if speed control recall work, if equipped was completed @ Recalls Look-up by VIN (Vehicle Identification Number); or @ Welcome to Ford Owner | Official Ford Owner Site; or ... have VIN ready. While there, see most Ford dealer maintenance/repairs done @ any dealership nation-wide.
See this guide by jowens1126 to confirm recall status @ 93 & 94-96 Cruise Control Recalls Repair
1994 Bronco Dealer Brochure by Ford via Dezo's Garage @ https://www.xr793.com/wp-content/uploads/2020/07/1994-Ford-Bronco.pdf
1994 Bronco Brochure, Partial; Cover & Page 3; plus pics of EDDIE BAUER model accessories.
by Ford via BigRob at 1994 Ford Bronco Bronco Accessories pictures, videos, and sounds | SuperMotors.net
For any Bronco questions such as the intermittent radio or transmission cooler lines, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 posts required to view due to scammers who preyed on our members.).
Our Forum FAQs includes for example, How to Use Search, How To Save (Bookmark) Threads Or Posts & more tips!
BabaLooey's Favorite FSB Links (lots and lots of tech links) ... includes such as, "Tailgate Window repair & troublehooting."
Try to find time to participate and Vote in our Full-Size of the Month Contest (soon to be Quarter) and later in the year Full-Size of the Year Contest @ Voting
You will get ideas by those competing.
Post a video with sound of your audio system when you have time.
Al
Yo Ron,
Al
Thank you for all of this. Super helpful information.
1981 Bronco, 4.9L, ZF5, NP208, Detroit Truetracs, 3.55 gears, 31" Wranglers front and rear
Welcome to FSB and congrats on the 94! An Allman Brothers Band Bronco - very cool!
Reactions: RonBronco
1 - 4 of 4 Posts
