Yo EB,
Welcome to our Big Bronco DIY Community!
DTC 112 to 114; Intake Air Temp (IAT); (Air Charge Temperature [ACT] prior to 1992) Troubleshooting & Possible Causes; Codes 112 to 114 will set a IAT sensor code in the EEC, remove and inspect the sensor it could get contaminated by engine oil , K&N oil (although in their site, they vehemnetly deny this is a cause... they picked and chose to "prove" the point) or dust. Clean the sensor with isopropyl alcohol. If the sensor still fails replace the unit
Cleaning w/Carburetor Cleaner in a 90 5.0; "...also noticed the intake air temperature (IAT) sensor was reading on the cool side, compared with the ambient air temp, so I pulled the sensor out of the intake and found Figure 5: a dirty IAT. I cleaned it with some spray carb cleaner and the truck passed the emissions test!..."
Source: by Brian M at asashop.org
Overview & Testing; "...This measures the temperature of the air entering the engine. Which impacts the fuel ratio; the cooler the incoming air is the denser it is. Denser air can utilize more fuel, giving us even greater accuracy in obtaining our desired air to fuel ratio. Before you start blaming the air charge temperature sensor and replacing it make sure the rest of the coolant system is in good condition. All of the following items will affect the ACT; Coolant level, Radiator Fan, Engine Temperature, read more @
Fuel Injection Technical Library » Air Charge Temperature (ACT)
Source: by Ryan M
Location in an Edelbrock Perfomer Lower Intake Manifold Diagram in a 90 5.8
Source: by SeattleFSB (Seattle FSB)
DTC 116 Engine Coolant Temperature (ECT) Sensor Troubleshooting & Possible Causes; "...The ECT sensor is a thermistor, basically a resistor that changes voltage accordingly to temperature changes. It provides a reading that's used by the EEC to change fuel delivery at engine startup to reduce emissions and monitors the temperature of the engine. If you see some rust in it clean it by sanding the surface using a fine grit sandpaper, Also check the connector and wiring..."
Overview & Testing by Ryan M (Fireguy50) @
Fuel Injection Technical Library » Engine Coolant Temperature Sensor (ECT)
DTC 636 indicates the output of the Transmission Fluid Temperature (TFT) sensor was out of Self-Test range. The sensor output shows a failure occurred at either the low or high end of the acceptable range. The correct range of measurement is from 0.76 to 4.69 volts for Escort/Tracer and from 0.21 to 3.50 volts for all others.
Possible causes:
Fluid levels not to specification.
Transmission fluid not at operating temperature.
Sensor resistance out of limits.
Damaged Powertrain Control Module (PCM)
See How to Troubleshoot a No Start (Ford 4.9L, 5.0L, 5.8L) by Abraham Torres-Arredondo @ How to Troubleshoot a No Start (Ford 4.9L, 5.0L, 5.8L) by Abraham Torres-Arredondo
ASAP, find out if speed control recall work, if equipped was completed. If you still have concerns about Recalls, please contact the Ford Customer Relationship Center:
US: 800-392-3673 | CA: 800-565-3673
Note: 3673 spells "FORD" on phone keys
For the hearing- or speech-impaired: Please contact the Telecommunication Relay Service by dialing 71
"Summary: ON CERTAIN PICKUP TRUCKS, PASSENGER VEHICLES, SPORT UTILITY VEHICLES, AND MOTOR HOMES CHASSIS, THE SPEED CONTROL DEACTIVATION SWITCH MAY, UNDER CERTAIN CONDITIONS, LEAK INTERNALLY AND THEN
OVERHEAT, SMOKE, OR BURN. THIS COULD RESULT IN AN UNDERHOOD FIRE."
Here's:
1995 Bronco Dealer Brochure @
1995 Ford Bronco
1995 Bronco/F Series Drivetrain, Powertrain Service Manual - Google Drive
The eight Groups found in this manual are:
00 - Service Information
02 - Engine and Transmission Mounting
03 - Engine
05 - Driveline
07 - Transmission
08 - Clutch
09 - Exhaust System
10 - Fuel System
Each Section covers a component or system. The second set of numbers on each page
indicates the Section.
If the vehicle has more than one type of component, such as two types of engines or power
steering systems, alphabetical suffixes are used.
1995 Bronco/F Series Chassis, Service Manual - Google Drive
To switch between folder list & grid views, click the button to the right of the "DOWNLOAD ALL" button in the upper right corner of the window) by HawkDriver
The twelve Groups found in this manual are:
01 - Body
02 - Frame and Mounting (Body)
04 - Suspension
06 - Brake System
11 - Steering System
12 - Climate Control System
13 - Instrumentation and Warning Systems
14 - Battery and Charging System
15 - Audio Systems
17 - Lighting
18 - Electrical Distribution
indicates the section.
See 1995 F 150 Powerstroke 7.3 Turbo Diesel Service Manual @
Ford Service Manuals - Google Drive
In pop-up, click "Drive"
Haynes Red Manual for 80-95 Bronco & F Series @
Hanes guide 80-96 bko f series.pdf via BroncMom!
See my mostly recovered
site by member schwim @
Ford Bronco And F-150 Links - FORD BRONCO
For any Bronco questions or to chat about it's planned modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as
Bronco and Ford Parts/Accessories (50 non-padded posts required to participate, due to scammers who preyed on our members).
Our Forum
FAQs includes for example, How to:
Post images
Save (Bookmark) Threads Or Posts
Search The Site
What is the Difference Between the Showcase and Gallery
How To Find Subscribed Thread and more tips!
See How to add your 95s Signature @ Bronco Forum - Full Size Ford Bronco Forum by BigBlue 94
Baba Looey's Favorite FSB Links (lots and lots of tech links)
... Includes such as, How do I fix my back window?
Take time to participate in our current Full-Size of the Month & later in the new year, Full-Size of the Year Contest @
Voting
You will get ideas by those competing.
Prizes are awarded to the winner!; a full spread in Bronco Driver Magazine is the top prize, in addition to a years subscription, once the article is submitted; and a years worth of premium FSB membership.
Al
