Hello,
This morning I noticed this new beeping noise in my 1995 bronco xlt, its got a factory alarm and keyless entry... The noise is only there when you first pull the key from the on, to the off position. as well as when the truck is in accessory.
it goes beep beep beep, then a pause, then repeats about 5 times then it stops.
the sound is coming from between the dash and the stereo deck. I have no idea what this sound is coming from and what it is trying to tell me what is wrong but my dad thinks its because of the alarm system. Ive read it has something to do with the fact the ABS, Airbag, or Check Engine light could be burn't out but Ive got no idea. Ive pulled the fuse for the alarm with no luck.
Thanks for any assistence
david
david
