What’s up fellas. I got a 1995 XLT and the driver door has been rattling when I hit bumps and such. I think it’s coming from the lock inside the the door panel. Anyone experienced this? Or recommendations on what to swap out. Much appreciated
Charlie don't surf..
'92 Ford Bronco XLT
As stated by @MS88Bronc , just make sure that before you remove the old striker, you use a sharpie to make around the striker assembly so you can put it back in the right place..otherwise, you'll have trouble opening and closing your door..good luck.
This may not be your problem since you suspect the noise is coming from the lock area but, I found several items, mostly nuts and screws down in the bottom of my door. The previous owner had dropped them and never retrieved them. They rattled when I went over bumps and when I closed the door.
I even found a Snap on flashlight at the bottom of the drivers door. I fished it out and got a charger and the battery and light were fine. I still use it today.
Yo ethood.
Welcome!
As advised on the bushings.
btw, watch out for the Dorman HELP brand stuff now....the driver/passenger door striker kit w/ bushings, 38445 are not fffin good..bushing diameter is way off and striker frame is off as well....it will bolt-in, but aligning it for a no-rattle fit is a waste of time and possible damage to passenger or driver.
Local dealership may have them too, but at a higher cost.
the Dorman HELP tail gate striker bushings pn 38424 are a good fit & the door bushings driver/passenger bushings are incl. in this kit & fit better than the 38445 part! Made from urethane thermoplastic. assortment contains 2 each of the following sizes: 1/2" I.D. x 5/8" and 1/2" I.D. x 1" which includes the Tail Gate Striker bushings.
DOORMAN HELP Bushings are avail @ almost all ADVANCE AUTO, NAPA, Auto Zone, etc.
There is a Captive Nut Plate; "...the strike bolt is a T50 (like the seat belt bolts). A cordless impact is invaluable. I also recommend some padded prybars to lift/slide the door without chipping the paint. As you can see in the pic under #1, you'll need a few extensions & a ratchet to break & set the bolts. All of the nut plates in the body are loose (for adjustments), but captive (they shouldn't fall if the fastener is removed), but anything can happen. If one falls, just remove the interior trim panel & retrieve it. To reinstall the strike bolt nut plate, you'll need to remove the bedside panel & peel the butyl (tar) pad away. The plate itself will be behind the shoulder reel on the floor, or on the bag of wadding crammed in down there..." I believe Bossind posted this awhile ago.
Door lock latch, "lubricate linkage, use Multi-Purpose Grease Spray D7AZ-19584-AA or equivalent meeting Ford specifications ESR-M1C159-A and ESB-M1C106-B." by Ford
ASAP, find out if speed control recall work, if equipped was completed @ Recalls Look-up by VIN (Vehicle Identification Number); or @ Welcome to Ford Owner | Official Ford Owner Site; or ... have VIN ready. While there, see most Ford dealer maintenance/repairs done @ any dealership nation-wide.
See this guide by jowens1126 to confirm recall status @ 93 & 94-96 Cruise Control Recalls Repair
1995 Bronco Dealer Brochure @ 1995 Ford Bronco
1995 Bronco Drivetrain, Powertrain Service Manual - Google Drive
1995 Bronco Chassis, Service Manual - Google Drive
To switch between folder list & grid views, click the button to the right of the "DOWNLOAD ALL" button in the upper right corner of the window) by HawkDriver
For any Bronco questions or to chat about it's planned modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 non-padded posts required to participate, due to scammers who preyed on our members).
Our Forum FAQs includes for example, How to Use Search and more tips!
See Baba Looey's Favorite FSB Links (lots and lots of tech links)
... Includes such as, How do I fix my back window?
Take time to participate in our current Full-Size of the Month & later in the year, Full-Size of the Year Contest @ Voting
Al
Redneck fix
Get a length of garden hose and cut a piece to replace the rubber part of the door striker. A little duck tape and your good to go.
This is one of my pet peeves when riding in my Bronco. I know it is a old truck... but if you slam my door.... next time you can walk.
