1 - 13 of 13 Posts
I have a 1995 bronco eddie bauer eddition with a 302 engine. It seems to lack power. I have to give it lots of throttle to go and on any small hill or head wind it downshifts alot and I have to keep it wound up.No check engine lights. Any good advice?
FSB Pimpster & Recruiter
First off Welcome to Our Home!
As mentioned above, searching would get you the answers you are looking for.
If I had to guess, My first guess is you having an issue with your Catalytic Converter.
Allcruisen :imp :usa
Check fuel pressure, timing, do a tune up - plugs, wires, cap and rotor.
Discussion Starter #11
I did replace the throttle position sensor when I first got it because there was no throttle response hardly at all. There was a code for that. But it improved it quite a bit, but it still seems slugish to me.
aka: kemicalburns
your running 33's with a stock gearing. that is part of your issue. you should have at least a 4.10 gear front/rear to move those tires especially with a 302.
search and do the Sixlitre Tune up. then figure on either a gear swap or running a 31" tire.
1 - 13 of 13 Posts
