1 - 3 of 3 Posts
1995 Bronco XL RABS light flashes 4 times and will run for a little while then turn off.
Your '95 has a 4 wheel ABS (antilock braking system). RABS is the older rear wheel only antilock braking system. Please clarify what exactly you are seeing (or video it and post it)
Yo highmay05,
Welcome!
4WABS Overview; "...The 4-wheel anti-lock brake system (ABS) prevents wheel lockup by automatically modulating the brake pressure during an emergency stop. By not locking the wheels, the driver can improve steering control during hard braking and stop the vehicle in the shortest possible distance under most conditions. The ABS controls both front and rear brakes separately.
Malfunction of the Anti-Lock Brake System will cause the Anti-lock brake electronic control module to shut off or inhibit the system. However, normal power assisted braking remains.
Malfunctions are indicated by the amber ABS warning light inside the vehicle. The 4-wheel anti-lock brake system is self monitoring.
When the ignition switch is placed in the RUN position, the anti-lock brake electronic control module will perform a preliminary self check on the anti-lock electrical system indicated by a momentary illumination of the amber ABS warning light in the instrument cluster. During vehicle operation, including normal and anti-lock braking, the anti-lock brake electronic control module monitors all electrical anti-lock functions and some hydraulic operations. In most malfunctions of the anti-lock brake system, the amber ABS warning light will be illuminated. However, most malfunctions are recorded as a coded number in the anti-lock brake electronic control module memory and assist in pinpointing the component needing service.
If system is OK, Code 16 will be present.
Most concerns which occur to the anti-lock brake system will be stored as a coded number in the Keep-Alive Memory (KAM) of the anti-lock brake electronic control module. This means that once a code is stored, it will be retained by the anti-lock brake electronic control module even with the key in the OFF position. The codes can be retrieved by following the on-board diagnostic procedures.
The amber anti-lock warning light will come on as soon as the vehicle is turned on or started to verify bulb operation, and will go out after 2-3 seconds, provided everything is normal.
When ABS codes are read out, code 16 will be present if the system is OK. This code is similar to the EEC's code 111. It basically means that the 4-Wheel ABS Electronic Control Unit (ECU) is indicating that everything is functioning properly electrically. In
4WABS Self Test & Test Connector Diagram, Component Locations, DTCs, 93-96; "...The 4WABS TEST Connector is red; located at the left-hand side (driver's side) of the engine compartment and marked ANTI-LOCK TEST;
➡ Light Flash Technique 1. Note: If 12V test light is not available, the amber ABS warning light also flashes during this test. Locate test connector in the engine compartment and install 12V test light between Pins C and E.
2. With the ignition off, jumper Pin E to B. 3. Turn key to RUN position. 4. Remove jumper between Pins E and B after 5 seconds.
5. Count light flashes of test light or amber ABS warning light..." read more; miesk5 Note; for all Resistance tests, battery needs to be disconnected; remove Negative cable at battery
Manually Clearing Diagnostic Codes:
All diagnostic trouble codes must be output, all concerns corrected (anti-lock light off) and vehicle driven about 40 km/h (25 mph) before diagnostic trouble codes will be erased.
Note: Do not raise vehicle on hoist and accelerate to 40 km/h (25 mph) to simulate driving the vehicle. Erroneous sensor codes will be set.
Automatic Memory Erasing: A diagnostic trouble code will be automatically erased if no system concerns occur for 50 ignition cycles.
The front inlet valves should read 5-8 Ohms each; all other valves should read 3-6 Ohms each. Sensors should read 800-1400 Ohms across the pins, and more than 10K Ohms from the metal shell to either pin. The pump motor sensor should be 5-40 Ohms. The acceleration sensor is a group of switches which should be closed when the truck is stationary & level. When the sensor is tilted ~1" up in the rear, pins 2-3 should go open; when tilted ~1.5" up in the front, pins 1-3 should go open.
Codes:
11 Possible Source(s):
� Anti-lock brake electronic control module failure.
Action(s) to take:
� REPLACE anti-lock brake electronic control module.
16 Possible Source(s):
� System OK.
Action(s) to take:
� None.
17 Reference Voltage/Intermittent Valve Fault
Possible Source(s):
� 30 amp fuse open.
� Intermittent connections to battery, main relay or ground.
� Main relay coil or contacts open.
� Open or short to ground in Circuit 532 (O/Y).
� Open or short to ground in Circuit 599 (PK/LG).
� Open or short to ground in Circuit 601 (LG/PK).
� Short to ground through anti-lock hydraulic control unit.
� Intermittent valve failures.
� High resistance valves.
22 Front Left Inlet Solenoid Valve Concern Diagnosis
Possible Source(s):
� Intermittent open Circuit 495 (T).
� Terminal backout in anti-lock brake electronic control module connector Pins 17 and 40.
� Terminal backout in anti-lock hydraulic control unit connector Pins 1, 4 and 6.
� Open or shorted inlet front left valve coil.
� Open or shorted driver in anti-lock brake electronic control module.
23 Front Left Outlet Solenoid Concern Diagnosis
Possible Source(s):
� Intermittent open Circuit 496 (O).
� Terminal backout in anti-lock brake electronic control module connector Pins 17 and 26.
� Terminal backout in anti-lock hydraulic control unit connector Pins 1, 4 and 7.
� Open or shorted outlet front left valve coil.
24 Front Right Inlet Solenoid Valve Concern Diagnosis
Possible Source(s):
� Intermittent open Circuit 497 (W).
� Terminal backout in anti-lock brake electronic control module connector Pins 17 and 34.
� Terminal backout in anti-lock hydraulic control unit connector Pins 1, 4 and 8.
� Open or shorted inlet front right valve coil.
25 Front Right Outlet Solenoid Valve Concern Diagnosis
Possible Source(s):
� Intermittent open Circuit 498 (PK).
� Terminal backout in anti-lock brake electronic control module connector Pins 17 and 15.
� Terminal backout in anti-lock hydraulic control unit connector Pins 1, 4 and 5.
� Open or shorted outlet front right valve coil.
26 Rear Axle Inlet Solenoid Valve Concern Diagnosis
Possible Source(s):
� Intermittent open Circuit 499 (GY/BK).
� Terminal backout in anti-lock brake electronic control module connector Pins 17 and 33.
� Terminal backout in anti-lock hydraulic control unit connector Pins 1, 4 and 2.
� Open or shorted inlet rear axle valve coil.
27 Rear Axle Outlet Solenoid Concern Diagnosis
Possible Source(s):
� Intermittent open Circuit 510 (T/R).
� Terminal backout in anti-lock brake electronic control module connector Pins 17 and 27.
� Terminal backout in anti-lock hydraulic control unit connector Pins 1, 4 and 3.
� Open or shorted outlet rear axle valve coil.
31 Left Front Brake Anti-Lock Sensor Diagnosis (Static)
Possible Source(s):
� Poor connection at left front brake anti-lock sensor.
� Terminal damage or backout in anti-lock brake electronic control module connector Pins 24 and 25.
� Terminal damage or backout in two-pin sensor connector.
� Open or shorted left front brake anti-lock sensor.
� Open or shorted Circuit 521 (T/O) or 522 (T/BK).
� Improper front left anti-lock brake sensor cable routing leading to above.
� Defective front left wheel speed sensor electrical test circuit in anti-lock brake electronic control module.
32 Right Front Brake Anti-Lock Sensor Diagnosis
Possible Source(s):
� Poor connection at right front brake anti-lock sensor.
� Terminal damage or backout in anti-lock brake electronic control module connector Pins 36 or 23.
� Terminal damage or backout in two-pin anti-lock brake sensor connector.
� Open or shorted right front brake anti-lock sensor.
� Open or shorted Circuit 514 (Y/R) or 516 (Y/BK).
33 Rear Axle Speed Sensor Diagnosis
Possible Source(s):
� Poor connection at vehicle speed sensor.
� Terminal damage or backout in anti-lock brake electronic control module connector Pins 21 or 22.
� Open or shorted vehicle speed sensor coil.
� Open or shorted Circuit 518 (LG/R) or 519 (LG/BK).
� Improper vehicle speed sensor cable routing leading to above.
� Defective vehicle speed sensor electrical test circuit in anti-lock brake electronic control module. Note: some vehicles were built using Circuit 523 (R/PK) in place of 518 (LG/R).
35
41
55
75 Left Front Brake Anti-Lock Sensor Diagnosis (Dynamic)
Possible Source(s):
� Damaged/missing front brake anti-lock sensor indicator teeth or missing front brake anti-lock sensor indicator.
� Air gap too small or too large.
� Excessive axle vibration.
� Weak front brake anti-lock sensor.
� Loose front brake anti-lock sensor.
� INTERMITTENT short or open in Circuit 521 (T/O) or 522 (T/BK).
� Disturbances caused by ignition or radio frequency interference.
� Defective trigger circuit in anti-lock brake electronic control module.
36
42
56
76 Right Front Brake Anti-Lock Sensor Diagnosis (Dynamic)
Possible Source(s):
� INTERMITTENT short or open in Circuit 514 (Y/R) or 516 (Y/BK).
37
43
57
77 Rear Axle Speed Sensor Diagnosis (Dynamic)
Possible Source(s):
� Damaged/missing indicator ring teeth or missing indicator ring.
� Weak rear axle sensor.
� Loose rear axle sensor.
� Intermittent short or open in Circuit 518 (LG/R) or 519 (LG/BK). Note: Some vehicles were built using Circuit 523 (R/PK) in place of 518 (LG/R).
51 Hydraulically Inoperative Front Left Outlet Valve or Sensor Disturbance Detected
Possible Source(s):
� Pinched or closed brake line or hose.
� Worn or clogged front left outlet valve.
52 Hydraulically Inoperative Right Front Outlet Valve or Sensor Disturbance Detected
Possible Source(s):
� Worn or clogged front right outlet valve.
53 Hydraulically Inoperative Rear Axle Outlet Valve or Sensor Disturbance Detected
Possible Source(s):
� Worn or clogged rear axle outlet valve.
63 Pump Motor Triggered but Did Not Run
Possible Source(s):
� Damaged pump motor.
� Terminal backout in anti-lock brake electronic control module harness connector Pins 17, 29, 37 and 38.
� Open or shorted pump motor relay coil.
� Open contacts in pump motor relay.
� Terminal backout in pump motor 4-way, Pins 1, 2, 3 or 4.
65 Acceleration Sensor
Possible Source(s):
� Terminal backout in anti-lock brake electronic control module wiring harness connector Pins 30, 31 and 32.
� Worn or damaged acceleration switch.
� Worn or damaged anti-lock brake electronic control module.
� Acceleration switch terminal backout, Pins 1, 2 and 3.
� Short to ground in Circuits 836 (O/W), 886 (O/BK) and 887 (Y).
67 Pump Motor Running but Not Triggered
Possible Source(s):
� Damaged trigger circuit in anti-lock brake electronic control module.
� Terminal backout in anti-lock brake electronic control module harness connector Pins 2 and 3.
� Welded relay contacts.
� Short to ground in Circuit 539 (PK/LB).
-- Amber ABS Warning Lamp On, No Code
Possible Source(s):
� Worn or damaged ignition switch.
� Open ignition feed circuit to anti-lock brake electronic control module.
� Low battery voltage (less than 8V).
� Blown ignition fuse.
� Open system ground.
4WABS Self Test Connector pic in a 95 (near driver's side hood hinge)
162333
Source: by s8c2 (the wagon)
See
4WABS Pin-Point Testing in 93-96 Bronco; This is same as in Ford EVTM/PCED/Workshop Manual
Source: by Ford via Chilton & me at FSB
4WABS Indicator Problem
ASAP, find out if speed control recall work, if equipped was completed @ Recalls Look-up by VIN (Vehicle Identification Number); or @ Welcome to Ford Owner | Official Ford Owner Site; or ... have VIN ready. While there, see most Ford dealer maintenance/repairs done @ any dealership nation-wide.
See this guide by jowens1126 to confirm recall status @ 93 & 94-96 Cruise Control Recalls Repair
1995 Bronco Dealer Brochure
1995 Bronco Drivetrain, Powertrain Service Manual - Google Drive
1995 Bronco Chassis, Service Manual - Google Drive
To switch between folder list & grid views, click the button to the right of the "DOWNLOAD ALL" button in the upper right corner of the window) by HawkDriver
For any Bronco questions or to chat about it's planned modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 non-padded posts required to participate, due to scammers who preyed on our members).
Our Forum FAQs includes for example, How to Use Search and more tips!
See Baba Looey's Favorite FSB Links (lots and lots of tech links)
... Includes such as, How do I fix my back window?
¤ See our Full-Size of the Quarter & Full-Size of the Year Contests @ Voting
Al
1 - 3 of 3 Posts
