1 - 10 of 10 Posts
Hello -
I am looking for some advice...
I have been struggling to find complete mirror assemblies,electric, driver side and passenger side mirrors. The suppliers that I have gone to have compatible replacement side mirrors but the quick connect electrical plug does not match to what I thought was original parts on my Bronco. The electrical plugs to my mirrors are 3/4" in diameter. After pulling it apart, the male side has 5 pins and the female side has 8 holes. When I shop around the electricall plug adapters are 1/2" in diameter and have less pins - like 3. Can someone tell me is there is a supplier out there who may have these mirrors in stock. Thanks in advance!!!
1989 Eddie Bauer 5.8, C6, True Trac diffs, 4.56 gears, 4" C&T lift, 130A 3G Alt, 35" Grabber AT2s
Do your mirrors have the turn signal indicator in them? If so, they are rare as hens teeth, and that explains the extra two wires in the loom. I have 5th gen power mirrors goin on my 4th gen, and they have only three wires.
You have the turn signal mirrors that's why your plug is different. They're extremely hard to find. And you'll pay big money to replace them.
I'd offer my set that I've had for over 10 years, but not sure I want to part with them yet.
Ye
Yes, my mirrors have turn signal indicators. When I talk to suppliers, they have a tough time give me the specs on the plugs, 5 pin, diameter, etc. Any suggestions on how to fix this dilemma?
I am okay not having the turn signals in my mirrors for the ease of replacement. The plug would have to be rewird and drop 2 wire, I guess?
so, if I want a replacement mirror, I probably wont find them new and will buy them off a private party? Thanks
you can also add the turn signal function yourself. i've seen people hook up LEDs to the back of the mirror to do so.
Yo 96
Section 01-09: Mirrors, Rearview
1996 F-150, F-250, F-350 and Bronco Workshop Manual​
REMOVAL AND INSTALLATION
Mirror, Power, Outside Rearview
Removal
  1. Removefront door trim panel (23942). Refer to Section 01-05.
  1. Disconnect outside mirror control wiring (14A684) on power mirror.
  1. Remove two screws attaching outside rear view mirror (17682) to the exterior of the front door (20124).
  1. Remove one screw attaching outside rear view mirror to the interior of the front door.
  1. Remove outside rear view mirror.
Installation
  1. Follow removal procedures in reverse order.
Glass, Outside Mirror
Removal
  1. Push in on the inboard edge of the glass assembly until it stops.
  1. Protect the mirror body with a rag or similar material at the outboard edge and insert a flat blade screwdriver (in about one inch) between the mirror body and glass assembly.
  1. Pry the glass assembly out from mirror body until it snaps loose.
  1. Remove the screwdriver and continue to pull the glass assembly by hand until it is completely unsnapped.
Installation
  1. Position the glass assembly in the mirror, making sure the U-shaped alignment tabs on the glass are lined up with the motor actuator bar and slightly move glass around until it drops into place.
  1. Push on the center of the glass assembly to snap it in place.
  1. Check glass for looseness. If loose, push on glass until it is fully seated.
Glass, Signal Mirror
Removal
  1. Protect mirror body with a rag or similar material at the outboard edge and insert a flat blade screwdriver (in about one inch) between the mirror body and glass assembly.
  1. Remove screwdriver and continue to pull the glass assembly by hand until it is completely unsnapped.
  1. Disconnect the two circuits (turn signal and ground) from the terminals on the back of the glass assembly.
Installation
  1. Connect two circuits (turn signal and ground) to the terminals on the back of glass assembly.
  1. Verify signal display operation by operating the right and left turn signals.
  1. Position glass assembly in mirror, making sure the U-shaped alignment tabs on the glass assembly are lined up with the motor actuator bar, and slightly move glass around until it drops into place.
  1. Push on center of the glass assembly to snap it into place.
  1. Check glass assembly for looseness. If loose, push on glass assembly until it is fully seated.
Mirror Control
Removal
  1. Insert a small, thin-bladed screwdriver into spring tab slots located at front and rear of window regulator switch housing (14527) and apply pressure to make the window regulator switch housing pop out.
  1. NOTE: The switch is held in place by an electrical contact pin.
    Remove three screws attaching connectors to window regulator switch housing.
  1. Remove outside rear view mirror control (17B676) by carefully prying the outside rear view mirror control from connector using a small screwdriver.
Installation
  1. Follow removal procedure in reverse order. The outside rear view mirror control is keyed to the connector and can be installed only one way.
Mirror Motor
Removal
  1. Remove the glass assembly as described in Glass, Outside Mirror in the Removal and Installation portion of this section. Mark the motor with tape or grease pencil to indicate top of motor.
  1. Remove the four screws attaching the motor to the mirror body.
  1. Pull motor away from the mirror body.
  1. Remove the plastic cover plate from the back of the motor. Pull off by hand.
  1. Use masking tape on the wires. Mark on the wire its location in the motor with the terminal number shown on the motor where the wires plug in.
  1. Carefully pull the wires/terminals out of the motor.
Installation
  1. Install wires into the motor by matching the terminal number marked on the wires and on the motor. Remove masking tape from the wires.
  1. Make sure wires are placed in the retaining slots in back of motor, then align the opening in the plastic cover plate with the wires on the back of motor and push on back cover.
  1. Make sure the rubber seal is properly installed on the motor.
  1. Position motor in mirror body using the mark (added during removal) indicating top of motor and line up the four screw holes.
  1. Install the four screws and hand-tighten. Do not overtighten.
  1. Install the glass assembly as described in Glass, Outside Mirror in the Removal and Installation portion of this section.
    ItemPart NumberDescription
    117682Outside Rear View Mirror
    162511
    2Power Mirror Motor (Part of 17682)
    3Screws (4 Req'd) (Part of 17682)
    4Outside Rearview Mirror Housing (Part of 17682)
    5Connecting Wires to Motor (Part of 17682)
    6Power Mirror Motor Cap (Part of 17682)
    7Power Mirror Motor (Part of 17682)
    8Rubber Gasket (Part of 17682)
    9Signal Mirror, Ground Wiring, Bronco Only (Part of 17682)
    10Turn Signal Wiring, Bronco Only (Part of 17682)
1 - 10 of 10 Posts
