Does anyone have a 1996 with an OBD-II PCM and a 5.0L engine with an E40D tranny? In 1996 Ford supposedly put the 4R70W and E40D behind 5.0L engines. I am trying to come up with either the PCM catch code or a part number for the computer with this configuration. I presume that there were different part numbers between the E40D configurations and the 4R70W ones.
I would really appreicate the help if someone has this setup.
Chillin on the Gulf Coast
I have a computer for that combo. I will check the number when I go to base.
yo,
I have it too
BTW, Ford did change calibration sometime during MY96 builds;
my 96 5.0 w/E4OD Calibration Code is 6-54J-R11 Ford # F6AE-6E-061-BK
Former Cal # was 6-54J-R10
See it & other CAL #'s on-line
Vehicle Emission Control Information (VECI) Decal; Contains Vacuum Diagram & Calibration Parts List for 88 & UP. On-Line for Free at Ford. Click "Quick Guides" in left panel; Scroll to & CLICK VECI Labels "Provides Vehicle Emission Control Information (VECI) and a related calibration parts list." Enter applicable info (need to know your Calibration number from your B-pillar sticker). Vacuum Diagram is the same as the one on the core support or hood or air filter cover. Suggest Right Clicking this Hot Link & Open in New Window
Source: by Ford @ http://www.motorcraftservice.com/
See TSB 96-6-9 for the Former Cal #6-54J-R10; which is shown in Ford’s VECI Label site for our 96 5.0
I am using the part you have to get to the catch code. Do you know if that have an ADA3 catch code?
OUT OF BUSINESS / M.I.A.
1996 5.0L E4OD ML1-442 DDS0 F6PF-12A650-BPA
1996 5.0L E4OD ML1-442 TAD0 F6TF-12A650-JA
1996 5.0L E4OD ML1-442 TAD1 F6TF-12A650-JB
1996 5.0L E4OD ML1-442 TAD2 F6TF-12A650-JC
1996 5.0L E4OD ML1-442 TAD3 F6TF-12A650-JD
1996 5.0L E4OD ML1-442 TAD4 F6TF-12A650-JE
1996 5.0L E4OD ML1-442 TAD5 F6TF-12A650-JF
1996 5.0L E4OD ML1-442 BNE0 F6PF-12A650-BNA
1996 5.0L E4OD ML1-442 KQL0 F6PF-12A650-BRA
1996 5.0L E4OD ML1-442 VIV0 F6TF-12A650-BAA
1996 5.0L E4OD ML1-442 VIV1 F6TF-12A650-BAB
1996 5.0L E4OD ML1-442 BXZ0 F6TF-12A650-BLA
1996 5.0L E4OD ML1-442 BXZ2 F6TF-12A650-BLC
1996 5.0L E4OD ML1-442 FZA0 F6TF-12A650-BMA
1996 5.0L E4OD ML1-442 FZA2 F6TF-12A650-BMC
1996 5.0L E4OD ML1-442 SSM2 F6TF-12A650-BNC
1996 5.0L E4OD ML1-442 VEE0 F6TF-12A650-KA
1996 5.0L E4OD ML1-442 VEE1 F6TF-12A650-KB
1996 5.0L E4OD ML1-442 VEE2 F6TF-12A650-KC
1996 5.0L E4OD ML1-442 VEE3 F6TF-12A650-KD
1996 5.0L E4OD ML1-442 VEE4 F6TF-12A650-KE
1996 5.0L E4OD ML1-442 VEE5 F6TF-12A650-KF
1996 5.0L E4OD ML1-442 WAX0 F6TF-12A650-LA
1996 5.0L E4OD ML1-442 WAX1 F6TF-12A650-LB
1996 5.0L E4OD ML1-442 WAX2 F6TF-12A650-LC
1996 5.0L E4OD ML1-442 WAX3 F6TF-12A650-LD
1996 5.0L E4OD ML1-442 WAX4 F6TF-12A650-LE
1996 5.0L E4OD ML1-442 WAX5 F6TF-12A650-LF
