1 - 20 of 20 Posts
1995 EB, 351W, Auto, Stock (for now)
I'm new here so please forgive me for starting yet another lift thread. I have searched through every thread I can find and decided to start a new thread in hopes it will help other folks in my situation. The big problem with the other threads is that most are OLD and I can't see any pictures. So...
Can y'all post pics of your FSB with either a 2.5" lift or 4" lift? If you could also post any details on the kit, tire and wheel size, ect. that would be REALLY helpful.
I have a 1995 with the 5.8L, everything is stock, and I just can't decide which route I want to go. Your pictures will help me figure it out. I absolutely do not want the back end to sit lower than the front, and 33's are as big of a tire as I am considering. This Bronco will likely never leave pavement (have another truck and a Mule for that), and is our family "toy". Any help is greatly appreciated. Thanks!
1993 F150 XLT 302 MAF A/T 4x4 2.5" Lift
4" is always good though depending on your usage the 2 1/2" might be better. If you use the truck for work or daily driving / parking garages with just little use off the road on trails imo the 2 1/2" would be better. If being used off road more then on road then the 4".
Addicted to Junk
94 bronco, 351w, 4" Skyjacker kit with new leaf springs option. 35x12.50x15 BFG AT on 15x10 Mickey Thompson Classic IIs.
If I might make one suggestion. Or three lol.
- Leveling springs suck for ride quality. If you do a 2.5" lift, do the whole kit and not just coils.
- extended radius arms ride much better than dropped factory arms
- get good shocks, it'll ride better.
depending on wheel backspacing, you may need to add a few washers to your front bumper or do a slight trim for 33's with no rub. This only applies to 92-96 from what I have seen.
Based on what you described, I think the 2.5" lift would be what you want.
I appreciate the info given so far. Post more pics fellas!
1986 Bronco, 351w, Edelbrock aluminum top end, Holley 600, 4" BDS lift, 35" Maxxis Razr's, stuff..
4” BDS front from Graveyard with bilsteins and 4” procomp springs in back with Sky hangers mounted to level. 35s on 9” rims. Rides great and flexes pretty good.
nice setup. did you have 3.55?
Discussion Starter · #8 ·
Biggum, that thing looks great. Thanks for posting!
Forgive me for hijacking this thread @Chance Love ..........
@biggum
I watched the video you attached of your truck, looks nice. I am wanting to ask about your bed liner paint job. I am thinking of doing the same thing. Are you happy with it? Any pros or cons I should know about?
Discussion Starter · #10 ·
You are forgiven...as long as you post a picture and details of your Bronco.😀
No worries here on the hijacking. I was curious about the bedliner paint job myself.
Ok, here is my truck. It has a 3" body lift sitting on 35" tires.
I would not recommend the body lift if you plan to off road a lot. Go with the suspension lift instead.
179389
4" BDS Suspension, 33x12.5R15 BFG A/Ts. Rear end is ever so slightly higher than the front. Bilstein 5100's all around, duals up front.
Reactions: reds and CZ Eddie
Yes, 3.55; it’s okay but 4:11 would be better.
Raptor liner. I’m happy with it and would do it again.
Discussion Starter · #14 ·
Quick question...If I go with a 2.5" lift, will 33x12.50's on 15x8 wheels, with 4" backspacing rub anything?
I have a 3" body lift on my truck and I used to run 33' tires. The only thing I rubbed was the radius arms when turning as tight as possible. You can keep that from happening by using the steering stops on your hubs. Other than that, your lift should be fine.
Discussion Starter · #16 ·
Thanks, man. I'll research those steering stops.
Here is a thread about tires rubbing on the Radius arms. I posted some pics of my "fix" to my steering stops on post number 18.
Discussion Starter · #18 ·
Thanks! That thread helps a lot. I'll definitely keep all that in mind when I get this project going. The pics are a major help.
1992 Eb Bronco 3” lift on 33’s
This is a 2.5 on 16x9 wheels with 285 75 16 tires. I like it, it bigger than stock but not big to the point where you have bad driveline angles.
179932
179933
1995 with a Stage 4 Solo rear set up and a hybrid of solo/giant in the front, about 4 inches, on 32x11.5x15 BFG AT's
1 - 20 of 20 Posts
