Steve83 said:
It's possible to run the batteries in quasi-parallel for most of the truck, and then in series for the winch, but it would be VERY expensive & sort of dangerous (2 grounds 12V apart). Most of all: it would be pretty pointless.
Use the first (main, original) battery to run the truck. Run 1 heavy wire from the +12V post of the starter relay on the inner fender to the (-) post of the second battery THROUGH a heavy-duty disconnect switch. Run a heavy wire from the second battery's (+) post to the winch's relays. That'll give you 12V to the truck & 24V to the winch.
When you're NOT winching, disconnect the heavy wire between the batteries with the switch & run a 60A fused jumper from the main battery's (+) to the second battery's (+), and ground the second battery's (-). That'll keep it charged. Just be SURE to disconnect those 2 charging jumpers BEFORE re-connecting the disconnect switch.
It could be done more quickly & safely with 2 continuous-duty (winch) relays, but I'd have to draw it up.
This is still not right, I dont think. The way your mentioning Steve, it will give you 24V across, the entire vehicle.
I was thinking somewatt of 4 diodes connected. 1 from the first battery + to the 2nd Battery -. Another from the 2nd battery + to the 1st Battery -. Then from the 2nd battery run a + with a diode {Keeping the current in one direction} to the Winch and a second diode from the - also to the winch.
Now, would that give me an isolated 24V? Or would I be connecting everything 24V?
Sorry about the confusion, I have been out for the past 9 Years.... :twak
Steve, the reason why I hate the idea of having to connect and disconnect in order too get the 24V is because you know in a Time of confusion and rushing to recover the vehicle, Someone is gonna forget to disconnect that 2nd battery and fry their rig.....
I know, recovery should be done with all caution and planned out right, but, thats just Murphy's Law......
I just dont wanna se anyone get hurt trying to connect 24V to a 12V system.
I am gonna go see my buddy tomorrow at the Marine Store. He might have just watt we need.....I ll keep everyone informed.
Allcruisen :imp :usa
PS Bill, You did nt want to ask this question? Or you just want me to look like the fool? LOL :histerica :histerica :toothless
