1 - 4 of 4 Posts
Did a search and found 4WABS threads but what about 2 wheel rear only ABS problems?
The light blinks off once and stays on steady. No blinking codes. the Bronco is a 1991 full size XLT with 125,000 miles and the 351 ci engine. Should I replace the wheel sensors, abs module, or ?
Jim
Driving Stuff Henry Built
There's a wire that you temporarily ground to pull rear wheel antilock braking (RABS) codes. There's info in post 8 of this thread on "how to", some testing routines, & more links. It's not complete yet, I've been adding flashout code definitions & testing routines as they come up. Let me know if you need another & I'll try to look it up.
There's pics of the test connector location from both a 90 & a 92 in there. Would you let us know which location is used in a 91?
Thanks,
I printed out the 2WABS section.
Both yellow ABS and red Brake lights were on, so I start at the beginning.
Jim
yo,
Good stuff by EL!
and here is some more, for posterity, just in case Sm or whatever goes away....
RABS Troubleshooting Flow Chart
This is from da Ford EVTM/Service Manual that you can buy via e bay; but make sure it is da Official Ford stuff and not the Chilton EVTM/SM crap
But El will prob post-up the pin-Point testing.
RBS Ckt by Steve
RABS Component Location Info in 90-92 Bronco & 90-96 F Series w/Ford Part Numbers
Source: by Steve83
RABS Functions Diagram
Source: by Steve83
RABS Self Test & Pin-Point Tests in an 88; PARTIAL, does not incl all Trouble Code (has DTCs 2, 4, 5 & 9 tests); Click NEXT to view all pages; miesk5 Note; for all Resistance tests, battery needs to be disconnected; remove Negative cable at battery
Source: by Jem270 at SuperMotors.net
1 - 4 of 4 Posts
