since the 20-6244 pump is unavailable has anyone tried this pump 20-6999.
You need the same adapter plate or I would assume the saginaw mounting bracket to replace you existing bracket..
Does any know about where to find the adapter plate?
I have happen to come across a power steering pump that seem to replace this one except for the fittings... if the adapter plate could be located.
the Cardone part # is 20-6999.
picture here...20-6999
http://i.ebayimg.com/00/s/NDA5WDMwMA==/$(KGrHqZ,!jIE6Id952s2BOiff!(8RQ~~60_1.JPG?set_id=8800005007
picture here...20-6244
http://images.whisystems.com/smartpages/partinfo_resize/A1C/206244-top.jpg
From Cardone Rep.
The pressure on the 20-6244 is 1080 to 1320 PSI, the housings are the same so you can bolt the bracket up. These are the same rotation. The fitting can be switched.
The 20-6999 has a pressure of 1280 to 1550 PSI...
I was wondering if a couple hundred PSI would create a problem or if anyone has tried this...?
Folks around here now swap out for the E150-350 cardone withthe bracket. I picked one up off or http://www.part-cars.com, a place in Minesota, paid $30 shipped for the pump with resevoire, pully and bracket.... :goodfinge
OUT OF BUSINESS / M.I.A.
20-6999 won't work without a lot of fab work, just get the correct bracket off a van and then you can use the standard saginaw pump
Discussion Starter #5 (Edited)
bracket...
will a 351 windsor bracket work from a 86 e250? for 351 modified 79 Bronco...??
I might have a bracket from a 74 Gran torino that had a "I think a Saginaw in it" with a 351M in it...
And if I get a saginaw bracket is there a saginaw power steering part # that works better for 4wd Bronco...?
