Done.
opc1:
You can get an idea of what I am looking for by viewing the 2008 calendar, you can click on "View Calendar Pages" under the pic on the order page to see each months Bronco1. Digital pictures only (sorry I just dont have time to receive prints and scan them myself, but you can scan and send the file)
2. the larger the better, ideal image size is 2300 x 1800 pixels
3. ideal DPI is 200
4. please choose 1-2 of your favorite ONLY
5. you may submit pics of multiple bronco's together, such as those from wheeling trips or meet and greets
6. .PNG image format preferred, then .JPG , then .PSD
7. Submit your name, city, state, bronco year, engine, trans, tire size & lift (if any)
8. Have fun with the pics, any subject or background, serious or goofy, clean or dirty, stock, modified, wheeling, etc etc
9. Please send the biggest picture file you can, I will resize and crop as neccessary
Thanks,Resolution and DPI are often used interchangeably, but they are quite different. Knowing the difference between them will enable you to get the most from CafePress.com's services.
Any digital image is composed of pixels. The pixels are the small colored square dots that can sometimes be seen when images are enlarged too much, or if you look at your screen close enough. Resolution is the number of pixels in the horizontal direction by the number of pixels in the vertical direction. For example, a picture with 1200 pixels at the horizontal direction and 2100 pixels at the vertical direction would have a resolution of 1200 x 2100 pixels (pronounced 1200 by 2100 pixels).
As you've probably noticed, nowhere in the above definition it is said what size the pixels are. This is where the DPI comes in. DPI is simply Dots Per Inch. A picture with 100 x 100 resolution would be 1 x 1 inch when printed at 100 DPI, and 100 x 100 inch when printed at 1 DPI!
There's a tradeoff. The bigger the resolution, the bigger the image is. It will take more disk space, occupy more memory when loaded, and will take longer to be transferred through the Web. On the other hand, the bigger the resolution, the better the image looks when printed. We feel it is better to wait a bit more for your photo to upload than to have a bad print at the end.
as stated in the original post, no later than nov 11Whats the deadline for sudmissions. I think i will try to get some new pics.
Sorry i guess i missed it, reading to fast. Will pic's from supermotors work.as stated in the original post, no later than nov 11
if they are large enough, i think supermotors resizes them from original sizeSorry i guess i missed it, reading to fast. Will pic's from supermotors work.
Pics coming when I find that right spot Joe.
:histerica Sounds like "in the garage" shots will work:goodfingeHave fun with the pics, any subject or background
he usually does a collage, where he trys to put in most submissions.Suggestion: You could include "inserts pics" in the corner(s) for honorable mention and such (like the pic of that dude with the tree branch shoved through his shoulder and pics of friends passed on). You could also include an additional page with small images (2 x 2) which would allow up to 40 more images (4 images x 5 images front and back).
yes...they are not allowed.Are there any rules against nudity or nekked bewbies in pics?
