1 - 4 of 4 Posts
Here's the full list of specs and dimensions for the Two-Door and Four-Door Bronco. The PDF from Ford is also attached below.
Bronco Two-Door:
Wheelbase:
  • 100.4 inches
Length:
  • Base: 173.7 inches
  • Big Bend: 173.7 inches
  • Badlands: 174.8 inches
  • Wildtrak: 173.7 inches
Height:
  • Base: 71.9 inches
  • Big Bend: 72.9 inches
  • Badlands: 73.8 inches
  • Wildtrak: 78.9 inches (with optional roof rack installed)
Width (with mirrors folded):
  • Base: 75.9 inches
  • Big Bend: 75.9 inches
  • Badlands: 76.3 inches
  • Wildtrak: 79.3 inches
Track Width (Front/Rear):
  • Base/Big Bend/Badlands: 65.0 inches / 65.0 inches
  • Wildtrak: 66.9 inches / 66.9 inches
Towing/Payload:
  • Max available tow: 3,500 pounds
  • Max payload: 1,170 pounds
  • Dynamic roof load: 110 pounds
  • Static roof load: 450 pounds
Off Road Capability
  • Ground clearance: 8.4/11.6 inches (Base/35 inch tires)
  • Suspension travel front/rear: 200 mm / 215 mm (Base) & 240 mm / 261 mm (Badlands)
  • Approach angle: 35.5 degrees / 43.2 degrees (Base/35 inch tires)
  • Breakover angle: 21.1 degrees / 29.0 degrees (Base/35 inch tires)
  • Departure angle: 29.8 degrees / 37.2 degrees (Base/35 inch tires)
  • Ramp travel index (sta-bar connected and disconnected): 427-610 degrees
  • Maximum water fording: 33.5 inches
Bronco Four-Door
Wheelbase:
  • 116.1 inches
Length:
  • Base: 189.4 inches
  • Big Bend: 189.4 inches
  • Badlands: 190.5 inches
  • Wildtrak: 189.5 inches
Height:
  • Base: 73.0 inches (soft top)
  • Badlands: 73.9 inches
  • Wildtrak: 75.3 inches
  • Base: 75.9 inches
Towing/Payload:
  • Max payload: 1,370 pounds
  • Static roof load: 450 pounds (where offered, not available on four-door models with 315/70R17 tires)
Off Road Capability
  • Ground clearance: 8.3 inches / 11.5 inches (Base/35 inch tires)
  • Breakover angle: 20.0 degrees / 26.3 degrees (Base/35 inch tires)
  • Departure angle: 29.7 degrees / 37.0 degrees (Base/35 inch tires)
  • Ramp travel index (sta-bar connected and disconnected): 417-537 degrees
FYI, it turns out the backup camera location is inside the spare wheel hub for anyone wondering...
Alloy wheel Wheel Rim Auto part Tire
1 - 4 of 4 Posts
