ok so i had this stuff on my old motor and it ran fine. no emisions ex egr, safc, msd 6a msd e coil,shorty headers,no cats wth 3in side pipes. now i bought this 85 up 302 ho .040 wit 1.60 rocker ,284 224 cam and it will not idle but when it does it still sounds like its skipping fuel wise bit i omed out each injector and unpluged each injector till i heard an idle drop. checked for vacuume leaks nad tried timing over and over but wont run right. above 2000 rpm its great but below that boy do i have fun trying to keep it from idleing up n down up n down.it will idle good then almost stalls and revs up and over and over till i slap the gas pedal. some times it idles great and it sounds like i have this bad as* cam but its not the cam its something else but what? my coolant blows over through the coolant resevrior till the radiator is dry. had a bad cap changed it and pressure tested the cooling system its ok but still blows over i keep having to refill it over and over so i dont over heat.cooling system was bled. not a head gasket. but i think that is due to bad timing. can any one help me with my run rough/idle problem? iac is good :banghead
