Sway's jealous of my
Does anybody know what size of serp belt I need to bypass my air pump? It does nothing for me anymore, and just makes a rackety noise (its air pipe is welded shut...thing is grenaded anyways I think). So I'm hoping somebody could tell me what size I need so I can go down to Napa and get it. I'm in that "mood" to work on the girl today. Take care of some stuff you know?
Discussion Starter #2
Btw, I searched and all I came up with was 2" shorter for 351W's, otherwise nobody has ever seemed to state a specific length for a 302 of my year deleting the pump.
NAPA Micro "V". P/N 060878. Measures out @ 88 3/8 in. Still on the adjuster scale, tho a bit on the tight side. If you've got a smaller alt pully for a high output 3G, then it falls almost right in the middle of the adjustment range.
Schrof
Do you remember how much you paid for your belt? I'll get around to getting it sometime this week..
Way too short for my 94. I BELIEVE my truck took a 92 and 1/8" belt to bypass my pulley. This is running straight from the crank up over the tensioner and around the alternator. Cost about 40 dollars. I think somewhere in 92/94 the routing changed? Either way, my air pump is bypassed. I hope this works out better for somebody later searching for help on this subject.
