21 - 26 of 26 Posts
1986 Ford Bronco
Discussion Starter #21
Can't hardly find headers that will fit for the GT40P heads, correct? That's a shame, since they burn cleaner and more efficiently that the GT40 heads.
1986 Ford Bronco
Discussion Starter #22
Also, do the 90s roller engines require solid or hydraulic lifters? I assume they are hydraulic, but thought I would ask.
The lifters depend on the camshaft... all lifters from 1986-1991 are the same for non-roller camshafts, 1992+ are a different PN and description says for roller camshafts... both are hydraulic.
1986-91 Lifters
1992+ Lifters
1986 Ford Bronco
Discussion Starter #24
I'm leaning toward Promaxx 1102 175cc aluminum heads. From what I have found out they are really pretty good for the price. Would these be a good head for a 302 roller?
Make sure the heads are good for roller cams. You might be looked at different springs, you'll need a pushrod length checker, and will you be buying aftermarket rockers?
Once you dip your toe into that pool, it's really hard not to dive in. At that point why not stroke it?
The 96 302 is roller (that's what I put in my 95EB you can see the engine on my build thread) but the heads aren't really any better than what you have.
If the Explorer engine is a good runner, you could do a simple rebuild, add a cam, and with the GT40 heads you should have no problem getting the power you want without dropping a ton of money and time. Get some plastigauge, get a Ford Rebuild book and a factory shop manual and let the kid build it. I can tell you from experience as a teenager who built a 327 for my first car (67 Chevelle) there was nothing like that feeling firing that thing up knowing I built it.
Of course the 327 became the original 396 built, then a Marine block 502 that sucked up my money faster than it sucked up leaded high octane.
1986 Ford Bronco
Discussion Starter #26
Haha! I hear you ctandc! He is going to help me build it and I have an email to the salvage yard that has the Explorer to verify the heads are GT40s and not GT40Ps. If it does have the GT40 heads, I'll get that engine. Those heads can be sent with roller cam springs. I imagine I will probably have to get aftermarket rockers of some kinds. I'm trying my best to keep the spend down on the engine, since he doesn't need a whole lot of power for his first car. Besides, if I was going to stroke a 302, I might as well get a 351.
21 - 26 of 26 Posts
