Pull codes from the computer for electric/electronic faults and begin diagnosis, go here now
www.oldfuelinjection.com was fordfuelinjetion etc. In some cases when it starts up fine, drive it and it either stalls/dies and won't restart immediatley until things cool down, it could be the ignition module is failing, TFI = thick film integated located directly on the distributor or module, remote location in the engine bay BUT either can be tested for FREE at most auto mparts stores but several times for passing grade otherwise replace.
Fuel relays can be a PITA usually located on the drivers side firewall/ fender area near the hood hindge, square looking...back probe, multimeter!
Other fuel manager sensors to check are TPS = throttle position sensor located on the bottom of the throttle body is voltage driven for blade angle air induction, IAC = idle air control sensor located on the right side of the throttle body can be cleaned with TB cleaner but only the bottom valve part or you could fry the solenoid attached. ECT = engine cooling temp sensor located in an "octagonal tee" which is threaded into the lower intake manifold up front, there's also a lower TB cooling tube hose as well.
Any issues with the fuel pump/sender unit in the gas tank.......?
Additional Help:
There is a Ford Racing Performance Parts "idle setting procedure" Instruction Sheet (Techline (800) FORD788) steps 1-9 on How To adjust idle by disconnecting the IAC using the throttle body idle stop screw, drilling out the mounting screw holes on a newer "plug & play" TPS so you can adjust it for voltage setting.
In the past the ideal setting was thought to be .93-.97 volts or just under 1 volt but recently posted information regarding this appears the setting should be between
.55v-.75 volts.
Posted by FSB member Jermil01 recently:
Wanted to update this thread based on some TPS adjustment information I got from one of my tuning sites. This goes against the conventional wisdom of setting the TPS closer to .95 range. Thoughts??
Regarding any ECU controlled function (and idling conditions in particular), before any strategy based adjustment can be made by a computer controlled system, it must first run somewhat normally in a default and OL mode.
To do this with a FORD you must first follow a few rules.
You must keep the TPS input above the deadband area and below the "tip in" area. On a FORD this equates to below approximately 0.9V and above 0.45. Anything above 0.90V the ECU thinks the throttle is starting to open. This brings into affect possible dashpot and fuel cut strategies which can turn one grey real fast. Below approx 0.40-0.45V the system suspects an incorrect input and substitutes a default figure.
So first off, the TPS should be set to around 0.55-0.75V.
You can also disconnect the IAC then disconnect the battery for 15-20 minutes, reconnect and the computer should default back to factory settings.
Good Luck ~ :thumbup
