yo,
DTC 556
Possible causes:
Inertia Fuel Shutoff (IFS) switch not reset or electrically open (if in primary circuit). Inertia Fuel Shutoff (IFS) switch not reset or electrically open (if in primary circuit). Check switch; pass side, inside kick panel;
reset the IFS switch by pushing the reset button on the top of the switch (refer to Owner Guide). Note in the closed position the Source: by Ford via miesk5 at FSB
Open or shorted circuit.
Damaged fuel pump relay. Pull FP Relay and ck for corrosion on terminals and in socket; some have found a bad wire there. Swap FP relay w/Horn Relay (or Trailer Marker Lamps Relay) in Power Distribution Box - Diagram in a 94 Bronco & F-Series
Source: by Ford via Steve83
Damaged Powertrain Control Module (PCM).
as I mentioned in another thread here; In place of the breakout box, go to the EEC pin instead; for instance - Measure resistance between Test Pin 22 at the breakout box and battery negative post.
.... Substitute EEC for "breakout box"
EEC IV Connector Pin Diagram
Source: by Fireguy50 (Ryan M)
EEC Connector Pin Outs, Bronco & Ford Truck & Van: 4.9, 460, 5.0, 5.8; miesk5 Note, see his Connector Pin Diagram Link above)
Source: by Ryan M (Fireguy50) at
http://fordfuelinjection.com/truckpinouts.html
Disconnect fuel pump relay.
Key on, engine off.
Measure voltage between VPWR circuit at the fuel pump relay vehicle harness connector and chassis ground.
Is voltage greater than 10.5 volts?
Yes GO to J2.
No VERIFY integrity of IFS switch. If OK, SERVICE open in VPWR circuit between the EEC power relay and the fuel pump relay. RECONNECT fuel pump relay. RERUN Quick Test.
J2 CHECK FUEL PUMP RELAY
Key off.
Fuel pump relay disconnected.
DVOM on 200 ohm scale.
Check fuel pump relay coil resistance:
For "ISO" relays, measure resistance between Pins 85 and 86 at the fuel pump relay (pin numbers molded on relay).
For other types of relays, measure resistance between VPWR pin and fuel pump circuit pin at the fuel pump relay.
Resistance should be between 40 and 85 ohms.
DVOM on 10,000 ohm scale.
Check fuel pump relay for internal shorts.
For "ISO" relays, (these are the Bosch style used in 92-96) measure resistance between Pin 85 and both Pins 30 and 87 at the fuel pump relay. For other types of relays, measure resistance between the fuel pump circuit pin and both the power-to-pump and B(+) pins at the fuel pump relay.
Both resistances should be greater than 10,000 ohms.
Are all resistance checks OK?
Yes GO to J3.
No REPLACE fuel pump relay. RERUN Quick Test.
J3 CHECK FUEL PUMP CIRCUIT FOR SHORT TO POWER
Key off.
Disconnect Powertrain Control Module (PCM). Inspect for damaged or pushed out pins, corrosion, loose wires, etc. Service as necessary.
Install breakout box, leave PCM disconnected.
Key on, engine off.
Measure voltage between Test Pin 22 at the breakout box and battery negative post.
Is voltage less than 1.0 volt?
Yes GO to J4.
No SERVICE short circuit. REMOVE breakout box. RECONNECT all components. ATTEMPT to start vehicle. If vehicle fails to start, REPLACE PCM. RERUN Quick Test.
J4 CHECK FUEL PUMP CIRCUIT FOR SHORT TO GROUND
Key off.
Breakout box installed, PCM disconnected.
Measure resistance between Test Pin 22 and Test Pins 40 and 60 at the breakout box.
Is resistance greater than 10,000 ohms?
Yes GO to J5.
No SERVICE short circuit. REMOVE breakout box. RECONNECT all components. RERUN Quick Test.
J5 CHECK FUEL PUMP CIRCUIT CONTINUITY
Key off.
Measure resistance between fuel pump circuit at the fuel pump relay vehicle harness connector and Test Pin 22 at the breakout box.
Is resistance less than 5.0 ohms?
Yes REPLACE PCM. RECONNECT fuel pump relay. RERUN Quick Test.
No SERVICE open circuit. REMOVE breakout box. RECONNECT all components. RERUN Quick Test.
