1 - 8 of 8 Posts
OUCH!!
do you have oil going into your air box as well. Anyway check to see if your spark plug is good. And if you do have oil in your airbox then you have a bad engine and will need to rebuild or replace
i SAY LEAVE IT A 7 CYLINDER TAKE THE SPARK PLUG OUT OF THE BAD ONE AND CAP TH HOLE, TAKE THE EXHAUST MANIFOLD OFF OF THAT CYLINDER RUN THE OPEN EXHAUST PORT TO AN AIR TANK AND AND REMOVE THE FUEL INJECTOR (BE SURE YOU CAP THE HOLE IN THE FUEL RAIL) YOU HAVE YOUR OWN CUSTOM ON-BOARD AIR :thumbup OR YOU COULD JUST FIX IT AND HAVE A NORMAL BORING V-8:brownbag
Now that's comedy..... :cool:
1 - 8 of 8 Posts
