1 - 20 of 26 Posts
Can I put 32's on my bronco with no lift? Tried a search but to no avail...Thanks for any help...
Full to Empty 6.5 Seconds
33's came stock from the factory? You sure??? I know they came with 235's stock but I seriously dont believe they came with 33's.
You can run 33's stock, hell for that matter, with a little fender trimming, you can run 38's without a lift. But the downside to that is you will almost need rear steering because you wont have much if any turning radius. I prefer 33's or smaller on the 78-9 broncos because they have a very small turning radius. My 78 will turn around in almost any area with the 31's that I have on it.
I bought mine with 31's on it and quickly sold them. I put on a new set of BFG A/T's 35X12.50-15. I had to do minor fender trimming but it was worth it. My 38's on Hummer rims will be on soon with a little more fender trimming, if required. Still, I have no lift. I'm going to make new radius arms with a little 'kink' in them for turning clearance, though.
So yes, 33's will fit. Sorry for the rambling...
32's on a 78?
Two evens make an odd!
scrounger extrordinaire
there are people running 42s with 4" lift so almost anything is possible
Discussion Starter · #19 ·
Thanks guys...I have a little while to make up my mind now...I bought a new set of 235/75/15 lt's to plow with...I'll go to a bigger set for the summer....
1 - 20 of 26 Posts
