ok... finally got the windsor in the truck and wired everything up. I have gas, compression ,and when i checked the spark at the plug it looked weak. have no clue why:scratchhe but this problem only came about after the alternator was hooked up. before the alt was put on in ran for bout a minute then died from the cylinders loading up with gas and wetting the plugs thoroughly. 4 and 8 are always the worse of the 2..my guess is the way the windsor sits higher in the front .who knows. tried it a couple more times after dryin the plugs blowin the cylinders out and changing the oil..but its still not running just get a couple pops then it loads up again.. someone told me 2 try a hot set of plugs and mess with the dist. till it fires. Sound Good? anything will be helpful!
thanks
ian
thanks
ian
