sorry to start a thread on this, but i am a carb noob. they suck.
but anyway, i wanted to check my understanding for setting initial timing.
i have 2bbl and mallory vacuum advance dizzy.
should a miracle occur and i get the carb running like it should, i would then set the idle per spec for having an auto (rolling with a C5 though i have not picked up the rig to count bolts etc).
I remove the vacuum line from the dizzy.
I plug the vacuum port on the dizzy.
I then set the timing with the light. I am thinking around 10 btdc.
for fine tuning i will have to get it under load and advance it til it pings.
then back it off a few degrees.
does this sound right?
