1 - 11 of 11 Posts
I am replacing a buddies 351M in his bronco with a 351W FI.
I purchased the specific motor mounts for a 78/9 bronco with a Windsor. But my simple question is will the steel brackets that bolt to the frame from 351M work with the 351W and the new motor motor mounts.
Also will the trans be located in the same position on the frame (ie will the crossmember and trans mount line back up). Obvisouly I have a different c6 as well to go with the Windsor swap.
fwiw I did search but most of used a different term as those threads didn't come up.
Thanks.
Don't know what motor mounts you bought. No 78 or 79 ever came with a Windsor.
I am pretty sure f150's came with weezers, just not the 4x4 flavor.
Went to napa asked for motor mounts for a 79 bronco with a windsor and they had a part number for them.
They list the modified, windsor and 6.6 as engine options for a 79 bronco.
Part # BK 6021265 cost me 7.99 each
Apllication based on motor mount part #
Ford Truck Bronco 4.7 L 289 CID V8 1966 - 1968
Ford Truck Bronco 5.0 L 302 CID V8 1980 - 1986
Ford Truck Bronco 5.0 L 302 CID V8 1969 - 1974
Ford Truck Bronco 5.8 L 351 CID V8 Windsor 1978 - 1986
Ford Truck Bronco 1975 - 1977
Ford Truck E100 1/2 Ton Econoline Club Wagon 5.0 L 302 CID V8 1971 - 1974
Ford Truck E100 1/2 Ton Econoline - Van 5.0 L 302 CID V8 1971 - 1974
Ford Truck E200 3/4 Ton Econoline Club Wagon 5.0 L 302 CID V8 1969 - 1974
Ford Truck E200 3/4 Ton Econoline - Van 5.0 L 302 CID V8 1969 - 1974
Ford Truck E300 1 Ton Econoline Club Wagon 5.0 L 302 CID V8 1969 - 1974
Ford Truck E300 1 Ton Econoline - Van 5.0 L 302 CID V8 1969 - 1974
Ford Truck F100 1/2 Ton - Pickup 4.2 L 255 CID V8 1981 - 1982
Ford Truck F100 1/2 Ton - Pickup 5.0 L 302 CID V8 1970 - 1983
Ford Truck F100 1/2 Ton - Pickup 5.8 L 351 CID V8 Windsor 1980 - 1981
Ford Truck F150 1/2 Ton - Pickup 5.0 L 302 CID V8 1975 - 1986
Ford Truck F150 1/2 Ton - Pickup 5.8 L 351 CID V8 Modified 1980 - 1980
Ford Truck F150 1/2 Ton - Pickup 5.8 L 351 CID V8 Windsor 1980 - 1986
Ford Truck F250 3/4 Ton - Pickup 5.0 L 302 CID V8 1970 - 1986
Ford Truck F250 3/4 Ton - Pickup 5.8 L 351 CID V8 Windsor 1980 - 1986
Ford Truck F350 1 Ton - Pickup 5.8 L 351 CID V8 Windsor 1980 - 1986
It came up with similar threads when I searched but not the ones linked to, and when I read through those threads I didn't find the info I was looking for.
Discussion Starter #11
Using the above listed motor mounts the engine fit perfectly.
1 - 11 of 11 Posts
