1 - 13 of 13 Posts
In order to pu 35x12.50 tires onto a 79 bronco, how much lift is required to do it with minimal amount of cutting? I'd like to keep the lift to a minimum if at all possible.
also where would be a good place to find lift components for my truck?
thanks
Check out bronco graveyard for lift kits. Their prices look good to me.
i run 36x12.50 and 4 inch suspension lift in front and 4 inch blocks in rear had to trim in the rear but i also added extended travel shocks etc, now i rub on inner part of wheel well in rear
this pic is before i trimmed the rear and u can see it hit in the front of the rear tire.
Discussion Starter · #10 ·
mainly depends how much your stock suspension has sagged over the years. drop the front coil tower down like an inch and a half or two, and do the rear shackle hanger flip, and you should be fine, this is if you are doing it on the cheap if not, buy a 3-4 inch kit and go on down the road.
When I bought my Bronco a few yrs ago, it had no lift..and some 35"x12.5 tires on it.
Never flexed it, but it worked fine for just plain old driving...cept for I broke some stock 3.55 gears and punctured the 3rd member...Nearest I can figure, it was from running fat tires like that.
Now, ARB and 4.11 gears seem to work well.
Or, did last time I drove it, a year ago.
had 35X13 on 10 inch rims with no lift on my 79..even with a fullsixe 35 spare on the rear carrier and the only place i could get it to rub was at full flex on the inside of the ds rear fenderwell
1 - 13 of 13 Posts
