Hello,
I've read every 3G article I've come across. Now I'm doing it myself and I have a quick question.
Is there any reason I couldn't use one of the split washers from under the pulley nut to space the v-belt pulley away from the 3g case? It fits perfectly on the metal ring (bearing?) around the pulley shaft that rotates witht he shaft. The only two things I could see wrong with using it are that it is split so it isn't flat (might cause the pulley to rotate abnormally)? I would think it would get more or less compressed flat when I tighten down the nut...but I dunno. Also, it is probably thicker than the 18 gauge listed elsewhere so the nut might not go on the bolt as far.
I know it is a cheap part but I'd really like to finish this today and everybody I've called has said they don't have washers with anywhere near a 3/4" diameter. I also haven't been able to find a washer in my misc stuff that I could drill out to 3/4 without making it worthless. Anyhow, any help would be appreciated. Sorry, I know it is probably kind of a dumb question.
