1 - 20 of 43 Posts
OUT OF BUSINESS / M.I.A.
Do I ever get any sleep from you folks ;) :toothless
Well I'm not the authority, but I've collected a lot of info and done the swap. So here does the info and LOTS of pics for the dial up people :goodfinge
This is a 2G Alternator or Ford 2nd Generation Alternator:
It has an external fan, not sure when they stopped using them.
2G's have 2 plugs in the back like this:
Which are not very good, the battery plug was a fire hazard!
Discussion Starter · #2 ·
This is a 3G Alternator which is Ford 3rd Generation Alternator.
The above case is from a 94-95 Mustang
Fords 3G alternator was a giant leap in technology and quality. The 3G was internally regulated, used two internal cooling fans, sealed bearings, and had a superior battery stud. The 3G’s were more efficient, and produced more amperage at idle than any of its predecessors.
This is the Old 2G wiring:
This is the 3G wiring:
This big difference is the Battery charge output. The 2G uses a connector that had fire issues. The 3G uses a threaded stud for a safer design.
Hey Fireguy nice pics.
So basically the connections are the same with the exception of the battery and this have 1 wire to the 2 fuse links instead of the 2.
Would that be the only wiring change, from your schematics that is all i can see, or am i missing something?
I am wondering as i want to switch mine to the 3G series.
Thanks
Actually the above picturea re more complex than it needs to be!
Those pics are from Ford engeneering diagrams.
To conenct a 3G to the batter a simply batter cable with eyes on both ends are all thats needed.
You can re-use that 1 2G plug but it ususally is old, and there is a nother smaller plug that you'll need anyway. I recomend getting all new connectors for the conversion. It doesn't cost a lot and makes for a new clean install
Discussion Starter · #14 ·
Dustball said:
The wiring is rediculously easy. I did a write-up four years ago- http://ylobronc.users.superford.org/alt1.html
I have since replaced the 8ga charge wire with a 4ga "battery to starter" cable.
Well why didn't you psot that link for the several alt posts up right now :beer
Crazed said:
I will be moving a few relays around while it is out, and I think I am going to re-loom everything.
BTW...there is a plug on the rear top of the 5.0 behind the intake....WHATSUPWITHTHAT?
Take a pic of that plug
my precioussssssss
Fireguy50 said:
65% of the 3G's are only 90AMP output. The other 35% are 130AMP output. The only way to be sure is to take the Alt to a shop and have it bench tested.
So even if I buy one brand spankin new, I wont know if my alt is actually cranking out 130amps?:shrug
1 - 20 of 43 Posts
