What have anybody else used to grind the alternator bracket? I was trying to figure out how to get the bracket out and notice the airpump bolt at the bottom edge of the bracket would be a royal bitch to remove. So do you grind it still attached to the block or do you remove it? and what did you use ?
Currently FSB divorced
I have serpentine belt still didn't have to mod anything.
collinsperformance said:
on v belts it goes right in. on serp belts i had to use a dramil or 4" angle grinder and cut a triangle out of the mount. i done all while still on the truck....mike
Thanks I picked up a few grinding abrasive points from sears so I will regive it a another try tomorrow.
Seeking Tanelorn
I used a grinder on it while it was in place. I also had to take a little off the bottom of the top part as well; the top of the alternator body hit it too, after I ground out the triangle at the botttom.
