1 - 9 of 9 Posts
Has anyone else had this problem? I put a 4" Rough Country suspension lift on this weekend and now my front driveshaft is hitting my trans crossmember. 1989 XLT with a M5OD. Any ideas?
Zombie Hunter
Geez. I gotta check that afterwork. I hope its something that easy. Thanks
this made me chuckle. not at you, but with you. I can't count the number of times i was just short of getting a hammer to make something fit, but then simply turned it around and there was no issues what so ever.
yes you have to drop the cross member. i have seen it done by cutting the crossmember on both sides of the driveshaft and building a drop U outta some angle or something and welding it back together. or you will have to find a drop crossmember bracket. i dont recommend flpping the shaft its not made to be that way.
aka: kemicalburns
he should not have to do anything to the cross member. the driveshaft just needs turned around is all. im running a 6" as are many others and dont have this issue.
1 - 9 of 9 Posts
