Well, my 302 probably at least needs a valve job. If I'm gonna pull the heads, I may as well just go aftermarket aluminum. If I'm gonna go aftermarket aluminum heads, I might as well get a cam. if I do that, I might as well freshen up the bottom end, too. And on and on. So why not build a SEFI 400 and put that in the 302's place? Sure, it'll guzzle fuel, but it won't be quite as bad as a 460, it's basically a Cleveland motor engineered for truck duty, so aftermarket aluminum cleveland heads are a win. TwEECer and the SEFI system from a Fox Body, help from TMeyer, etc....we can really do this! The only real issues left are....
Accessories.....do I have to use the circa-70s V-belt nightmare, or is there a factory style serpentine setup I could use? Could I make brackets to mount my 302's accessories onto the front of the 400 and run the serpentine setup like that? I don't want an obnoxious showy billet setup, I just want function.
Will it mount? I recall reading that the 335 series motors and the 385 series motors share motor mounts, ie I'd have to get the engine crossmember and mounts from a 460 truck and put them on my Bronco frame. Is this correct?
Transmissions.....I'm a manual-guy. I know the 400 has the big block transmission bolt pattern. Could a ZF5 for a 460 bolt right up to the 400? I've read something about not enough pilot bearing contact with that setup, but nobody else verified.
I'll probably keep adding questions as I start getting into the 400 I got for the cost of an oil pump. If this can't be done, I guess I need to find a roller ready 351 block and get to work on it....but I'd really rather have the 400.
Also, those with experience, feel free to point out errors in my ways and thoughts...or lack thereof.
