pulled 452, 628 and a 332 on the bko this weekend
332 Egr valve not opening
452 error in the VSS and PSOM during last 8 warm up cycles
628 converter clutch lock up error (E40D)
i plan on cleaning to EGR if i can get to it, to see if that helps
w/ od on or off i never get any different results and the button never flashes
when i take off i can feel a low speed TC shudder and slippage, 3rd and 4th work fine, but the biggest slippage is rite at takeoff, after i pulled the codes i cleaned what i thought to be the VSS connections by the rear end and that really didnt do much, i just recently did a full system flush, but im curious on how people say they flushed the "TC"???? i just disconnected the cooler line and filled while it spilled, did that do it well enough?
my biggest question is that i can put the truck into 1 and it will work fine for takeoff, so this leads me to believe that there could be a valve body blockage?? i would really like to just replace the TC and see how it comes out, money is the biggest hurdle here, i need to sell it b4 i fill it w/ cash and then get nothing outta it
i have throughly searched this subject for a while any input would be appreciated
· The Anti Yam!
Test the EVP.
http://fordfuelinjection.com/index.php?p=35
Use the following test to see if the EGR is actualy opening.
Gacknar said:
Here is a simple way to see if the EGR is reacting to vaccum.
1. Remove the vaccum line from the EGR valve.
2. Take a length of vaccum line and attach it to the now open vaccum port on the EGR.
3. Place the other end of the vaccume line between your lips.
4. Watch the EGR diafram looking threw the holes in the EGR housing.
5. Suck (this will create vaccum on the EGR diaphram)
6. If the diphram moved then your EGR valve is probably working properly.
anybody got any suggestions for the trans part??? how much and where could i get a cheap rebuilt TC?
