I have a 5 speed from an 89 F350 4x4 that had a 460. Will this transmission bolt up to a 7.3 diesel? If not is there an adapter plate I can buy?
FWIW, the diesel uses a narrow ratio transmission. The wide ratio tranny may make the truck tough to drive as you need to rev the engine exessively in each gear between shifts.
Couldn't I offset that with lower gears in the axles?
The problem isn't the final gear ratio, it's the spread between gears. A gas engine has a range of about 4-5000 rpm to play with, the diesel only has about 3000-3500. The ratio between gears in the diesel tranny is tighter to accomodate the lower rpm range of the engine.
FSB warrior
In other words
Gas
5.72, 2.94, 1.61, 1.00, .76
Oil
4.14, 2.37, 1.42, 1.00, .76
it wont even bolt up.........
