1 - 4 of 4 Posts
I've seen a few posts talking about them, but anyone actually installed a factory 460 cooler on a 302/351? I got the whole setup from the junkyard and it bolts up, but it looks like the block adapter points the filter straight into the crossmember.
Basically seems like the block isn't long enough to make it fit...
Anyone had this problem?
Thanks for the info, Im gonna try to do it without cutting the frame:thumbup Do you guys know the part number of the shorter filter?
Good pics kf4amu
Can that plugged port in the block adaptor be used for an oil temp gauge?
1 - 4 of 4 Posts
