1 - 3 of 3 Posts
I have a 79 FSB that had a 460 in it with a c6 auto.. Until i blew it up. I just bought a 2wd 77 f350 and i intend to use the straight six and 4 speed tranny in my bronco. My question is what all would i need to do in order to match up the 4 speed tranny out of the 77 withe the 4wd tcase in my 79? Ive never done such a project and any help would be much appreciated.
you probably need a different main output shaft in the transmission as the trans will need the tail stock removed
not sure if just unbolting it will mate up to the t case
you will also need to get different driveshafts as the stick trans i shorter i believe and you will need a longer rear and shorter front shaft
i have both a c6 and a np435 trans mounted to a 205 case, i can get dimensions tomorrow if you need them
wow, from a 460 to a 300, big change there
1 - 3 of 3 Posts
