This is a copy off my webpage http://fireguy50.com/bronco/brakes.html
For discussion here on the forum
2002-04 Lightning 4wheel disk 1-1/4" bore Master Cylinder
Stock 1980-96 Bronco Power Brake Booster
Proportioning Valve from Summit Racing
1967 Mustang Distribution Block (no proportioning valve)
1972-79 ThunderBird 3-1/8" bore Front Calipers
Stock 1980-96 Bronco 11.72" Front Rotors
1983-97 4WD S10 2-1/2" bore Rear Calipers
1977-86 Jeep CJ-7 11.75" Rear Rotors
I had brake problems, and I drive too fast to depend on the stock brakes. My first problem was the combination valve mounted on the frame. After 20+ years I could tell a buildup of sludge was in there. I couldn't blow air through it, so I knew brake fluid couldn't freely flow to the front calipers. Replacing it would be costly and I didn't need the built in drum brake proportioning valve. I replaced it with a simple distribution block from a 1967 Mustang, and a separate adjustable proportioning valve.
My second problem was finding a good rebuilt master cylinder. I didn't trust the rebuilt master cylinders using 20+ year old cores. So I choose a newer style aluminum master cylinder from a 2002 Ford Lightning Truck. It has larger 1-1/4" bore which fill the larger calipers pistons quicker. I am very happy with this decision, the whole system works great!
I kept the stock power brake booster because I've never had a problem pushing the brake pedal.
PLEASE DO YOUR OWN RESEARCH, MY IDEAS MAY NOT WORK FOR YOU!
Master Cylinder, Adjustable Proportioning Valve & Stainless Steel Lines
Distribution Block & Stainless Steel Lines
Front Brake setup
Must have the early 80's knuckles to use these larger calipers
Rear Brake setup
