Hi there,
I've got an 88' bronco with an electric 4x4. I swapped out the 302 efi for a 351 and the aod tranny for a zf5 and now i can't get the 4low to work. The 4x4 high/low worked fine before the swap and will still go into high with the ZF tranny. However when i push the 4low button it just flashes. I know your supposed to have the tranny in neutral but its just not working. Any suggestions?
soudns like something seperate from the zf if it can still engage 4 hi. convert it to manual...
Thanks for the help. That would more than likely be my problem.(Can't believe i forgot about that after doing the swap) Guess i'll be splicing some wires together tommorow. Thanks again!
