i have a 1988 bronco with 302 with aod that i am swapping out motor to 351
i have motor and computer out of 1992 f150 that had 4eod. will this computer work for my 88 with aod after i swap motors? also is there a quick link to swap infromation ? i have searched but not sure i looking in right spots .
thanks for the help
The Anti Yam!
It will work but you will get the codes for the missing tranny and it may turn on the Check Engine light. But it would run fine.
As far as swaps, go to search. Put in 5.8 swap and switch it to "search thread titles only"
You should get lots of stuff.
The Anti Yam!
jwhit said:
could i use a 302 ho computer ??
No.
jwhit said:
i treid searching as you said still no luck , am i doing somthing wrong?
I dont know, hold on I'll try it myself.
aka: kemicalburns
no you cant use a 5.0 ho ecu.
you will also need a flexplate from an 80's crownvictoria running 5.8/AOD. do not use the e4od flexplate ok it will not work.
search 302-351w swap
The Anti Yam!
Apparently, I get pages of replies when I do it.
You went to Search
under keyword you put in 351 swap
switched it to "search thread titles only"
and got nothing?
Becouse that should work perfictly
