92 5.0, work in progress
Anybody found a good lift combo to fit 35x13.5x15s on 15x10 rims? I’m trying to figure out if a 6” suspension will do the trick( if I replace the bumpers to account for any front rub). I was eyeballing the JBG 6” ultra deluxe with extended radius arms and new rear springs.... no blocks.
thanks for your input
Appreciate the response. And thanks for your service! It’s gonna be a long road, but eventually I’ll get there. The wife wouldn’t let me buy a new one, so I’m he’ll be t and determined to spend the same amount on this one. Haha.
Did you do anything special, or was it all bolt on? Any special rim offset?
Moderator and Scrounger Extraordinaire
You will be golden with a 6" lift. 3.5 or 4" backspace on the wheels.
Definitely get a kit with extended radius arms. They ride and flex so much better than RA drop brackets.
35" BFG mud terrain radials on 15 inch rims with no lift... sagging springs... but a little bumper trim. I didn't like the low rider look ….. so I put the 31X10.50 BFG All terrains on the front and left the35" on the back ...… drove the crap out of it with a front rake for months.
I going with a 2.5 leveling kit to just get enough clearance … with new springs it will probably net me close to 4"
Never had a issue in the rear running 35" with the stock set up
