Folks,
Last month I bought my dream truck, a 78 Ford Bronco! I'm in the process of taking out the 4 inch body lift and converting it to stock height with poly busgings from Jeffs Bronco Graveyard. Since the kit that I took out is not stock, its tough for me to match up which bushings go where. The new kit has no instruction.. Does anyone have experience with the 78/79 JBGY kit and matching up the bushings and steel sleeves?
Any help would be greatly appreciated!
Thanks! I do have it set up loke that.
I guess the only remaining question is if i have the top and bottom isolators matched up and if theyre in the right locations.
The truck had a 4 in suspension lift and a 4 in body lift. Im taking the body lift out becuse the poly bushings look new but theyre all torn up from abuse.
I believe that there is an extension in the steering gear box. Could this be the reason that the front isolator has a gap between the body?
How much of a gap? You may have an extension on your shift lever as well.
The gap was around a half inch or so. When I loosened up the passenger side, it sat down. Now when I look at it, it appears to slant by that much towards the driver side. I may simply add washers to raise it.
I did have to cut and weld the shifter linkage, but I destroyed the rubber insert that connects to the column. Any idea where I can buy this?
Also, I noticed that it idled waaaay too high. Are the foot pedals usually adjusted during a body lift?
