1 - 11 of 11 Posts
1979 Bronco Ranger XLT, 400m engine, C6 trans, D44 front with Dick Cepek manual locking hubs
Is this possible?
I have each one bad stud each side of front axle, basically I try to avoid opening up everything from the locking hubs, etc.
Is there any way to change the studs without removing it all?
ok, quick and answered, so I will try my self in dis-assy and assy with regreasing hubs.
You will need a spindle nut socket for dana44
a small pick.
torque wrench
Maybe Snap ring pliers
are the lock out hubs stock?
Use very light grease on the hubs
Can you give me a link where to get the spindel nut socket?
i have some tools, not everything though...
1978 Bronco Ranger XLT, 400/C6 92 K documented miles &1994 Bronco,XLT 85K original miles
Sim,
Not a big deal to disassemble the hubs. Just place the first parts you remove, (6 bolts) on paper/cardboard, in succession to the inner seal, then reassemble in reverse. You can check the engagement/disengage during this process. No big deal.
Discussion Starter #11
yeah, ok !
I need to stop being shy of those things.
today I will mount the GT bar and start with rear carpet and bench mounting parts.
when nut arrives, I will go into the hubs.
1 - 11 of 11 Posts
