1 - 3 of 3 Posts
G'day all,
OK, here's the deal, I got a '78 Bronco with a NP205 T case, but the rear end is a 8.8 out of a '86(truck or bronc, I have no idea).
Problem is, Need a new rear drive shaft, my slip yoke is shot.
So, when this shaft(stock to the 78) was put in we had to build a custom u-joint from 3 joints total(and mostly chevy parts, at that!) to get cap diameters and cross widths to match the shaft to the 8.8
Question is, if i buy a rear shaft for a 86 bronco, it should mate to the 8.8 perfectly(Right?), but will the upper joint be the right one to mate to my 205?
Obviously I'm gonna take the old one in when I get the new one and measure all caps and widths on it and what I get, but it'd be nice to know whether to expect this to work or not. Or whether i should just plan on having to spend the extra $$ to build the custom joint...(not a great prospect since the shaft itself is costing me $300+)
Thanks for any help,
Gary.
Here are some general notes on 4x4 Universal Joints & Driveshafts:
Universal Joint Types
Cardan Style
Constant Velocity (CV)
Universal Joint Series/Sizes
1310 Universal Joint
3.219" (3-7/32") Wide / 1.062" (1-1/16") Diameter Caps
1330 Universal Joint
3.625" (3-5/8") Wide / 1.062" (1-1/16") Diameter Caps
1350 Universal Joint
3.625" (3-5/8") Wide / 1.188" (1-3/16") Diameter Caps
1410 Universal Joint
4.188" (4-3/16") Wide / 1.188" (1-3/16") Diameter Caps
Odd Hybrid Universal Joint
1310 to 1330 / 1.125" (1-1/8") Diameter Caps
Other Crossover Hybrid Universal Joints are available.
Driveshaft Types
Single Cardan
Double Cardan
Driveshaft Variable Length
Slip Yoke Shaft (Slips in & out of the transfer case)
Slip Member Shaft (Slips mid-driveshaft)
Yoke
Pinion Yoke (Attaches directly to the Pinion Shaft)
Companion Flange (A fixed flange member with a bolt on Yoke)
Causes and Remedies of Driveshaft Vibration:
Improper universal joint operating angles / improper driveshaft geometry
- Measure and set proper geometry
Too extreme universal joint operating angles
- Switch to higher angle capable u-joint series or CV joint
- Reduce operating angles (reduce suspension height)
Poor balance of driveshaft assembly (common)
- Have driveshaft professionally balanced
- Ensure proper phasing
Driveshaft balance weights damaged or missing
Worn-out / improperly lubricated U-joints (common)
- Inspect, lubricate, replace u-joints as required
Worn tail-cone / slip yoke or slip member
- Inspect and replace worn components as required
Bent, dented, fractured tubing
- Inspect and repair/replace as required
Here is an excellent link from Pirate4x4.com to everything you wanted to know about 4x4 Driveshafts: BillaVista Tech Garage Driveshaft 401. I know that this probably didn't answer your specific question, but it will give you some good information to refer to.
Thanks, thats a lot of info... at least now I know the proper term for what everyone here calls a slip yoke.. Slip Member Shaft... Thats whats worn on mine, I can flex the shaft at that point a good 4 or 5 degrees..
The more i think about this, its real simple; all I need to know is if the yoke on the transfer case on a '86 bronco is the same as it is on a '78. And if they're different, what the numbers are so i can get a cross over joint like mentioned above(Didn't know those were made..)
1 - 3 of 3 Posts
