1 - 14 of 14 Posts
U-Joints for the '79 are bigger then '78, so the shafts are not interchangable. Jeff's Bronco Graveyard sells new drive shafts for about $300.00, otherwise, start checking the junkyards.
You can buy u-joints that are designed to put the 78 shaft in the 79 or vise versa. The u-joint has 2 different size ends on it. 2-1/2" for the 78 and 2-3/4" for the 79.
Are rear shafts supposed to have a cv from the factory. My 79 SB truck has a cv front and rear on stock suspension, i'm not complaining, just curious?
so how do you get one of those to work in a CV assembly?
Mine didn't on the rear of my F150 and the 78 Bronco I had didn't have them front or rear. It all depends on the tranny/tcase combo.;)
f150's have a non cv rear.
broncos all had them front and rear in 78/79. if you got one that does not have them some one swapped them out for non cv shafts.
Retired
Yep had a 78 with none front or rear. Someone may have swapped the Bronco's but I knew the F150 came factory the way it was. I knew the original owner (brother inlaws father) and I am the 2nd owner of it.
1 - 14 of 14 Posts
